Go Back   Toyota Supra Forums! Join the Supra forum! > Supra Specific > Car Audio and Alarms
Old 06-24-2005, 08:03 PM   #1
midwestmk2
midwestmk2's Avatar
Ill have to say yes to Alpine but only for head units.. If it comes to subs id have to go with LANZAR.. I had 4 10"LANZAR heritage series 800watt subs running off a Rockford 500a.2 bridged mono..It was all in a 86 cuttlas with a set of 1000watt 6x9's and 500watt 3" peizo tweeters in the dash..They hit so hard that the speedo would jump up at stop lights and could blurr my vision on the highway with the windows down.. :blink: The whole setup only cost me $800 with every thing including the wireing..Nothing like having truckers looking over at you on the highway or over blasting someone who thinks theres is loud..Setting off car alarms for 50 yards,Beautifull.. B)
Old 10-06-2005, 09:22 PM   #2
caraudio
caraudio is on a distinguished road
Hey id have to agree lanzar heritage serise is a great set. I got 2 12" 124D's in a Band Pass 4 port box. Now with a Vibe 248 amp pushing 500RMS per channel its good only thing amps getting kinda really hot so at these settings it sounds n hits fine just the heat issue:
HU Settings:
Bass +12
Trebel +12
Sub Lvl +4db (max +/-6db)
Sq Set 60hz+6 (can be +12 or 0)
LPF Hz 80
HPF Hz 180
Amp Settings:
Amp level is about 85%- 90 up.
LPF about 25% like that on the amp gain to the left so you can turn it up more but its pretty low.
HPF about 70% to the right of the adjust(gain) knob.
Freq Amp set: Low
Thoes are my settings
These are the settings so ya maybe any one have any reccomendations and stuff id love for some help at fine tuning my system. My hole system is.
Panasonic 50x4 watt deck
2 Infinity 6002i's
2 lanzar 12" 124Ds 1000RMS
1 Vibe 248 amp 500rms at 2ohms / chan.
THANKS!
caraudio is offline   Reply With Quote
Old 10-24-2005, 04:05 AM   #3
Tater_Salad
Tater_Salad is on a distinguished road
are you guys serious? alot of those are cheap crap... check out www.REaudio.com or www.edesignaudio.com or ascendent audio, avionixx amps... only worth while subs and amps unless you can afford some JL w7s or w10s. as for head units I only go for eclipse by fujitsu ten.
everything else is garbage. I dont care if it bumps super loud if it sounds like an ass its not worth anything.
Tater_Salad is offline   Reply With Quote
basic oil stuff tone loc Off Topic Forum 8 10-24-2006 08:19 PM
how to take off all emmisions stuff boner1115 MKIII Supra 6 11-05-2005 04:27 AM
