Old 07-29-2011, 11:23 PM   #2
mirage83
Originally Posted by a400tool View Post
Yes, fan shroud is in good shape as is the engine under cover.
Damn, was really kinda hoping you'd respond that your shroud was mangled or missing.
How confident are you in your fan clutch? The fluid in them can leak out over time which prevents it from spinning up properly when you're idling.
Also, have you pressurized your coolant system to see if one of your hoses has a weak but not obviously blown area?
Forgive the questions, just trying to hit all the reasonable bases before you go digging into your radiator and water pump.
