Old 12-05-2010, 03:46 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by 2jzFUN View Post
Well I think that I am going to go with a set of gsc s2 cams, slight port clean up job on the head (stage 3), and I just need to figure out what valves and springs are the best. Shimless buckets? This is new to me so ill be reading up on the best combination.
Shimless buckets are cool, but only needed if you'll be running really high rpms (>10K).
In general, 9s is easily doable - on the oem shortblock (yep, I mean 100% bone-stock)! Did MA Performance mislead you to think you needed to build the shortblock for this project?
Again, there's no need to build the engine at all - just slap in a set of 272 cams! After that, all you you need is a moderately large single turbo (eg 74mm+), fuel system, AEM, TH400, slicks&skinnies. Maybe a small shot of nos to spool, and disconnect the front swaybar. That's about it for '9s in-a-box' with the Mkiv Supra Turbo.
Life begins at 30psi.
