Old 03-18-2010, 02:21 AM   #1
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
Double check the diagram to be sure as to whether you jumper the two wires or sever them.
I cut the hood switch connector off and twisted the wires together. We'll see how that works. I can't tell by looking at the wiring diagrams if they're supposed to be twisted or separated in order to fool the computer into thinking the hood is always open and preventing it from arming the alarm.
The "security check" light never comes on--except when the key is first turned on, so the light bulb is good. But we have always locked the car using the inside door lock buttons--never from the outside key.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
