Old 02-22-2010, 01:41 PM   #1
Cameroonski
Cameroonski is on a distinguished road
Originally Posted by suprabahamut View Post
See if you have any codes first. When you pulled the motor up did you disconnect any sensors like the knock sensor. It could be something pretty simple. Also with a new clutch make sure you do a break in, it might possibly be the clutch with the loss of power feeling.
yes i checked it for codes and it said everything was normal. And yes I havent gone over 3500 rpm, mostly shifting at 2500. But that is not the problem unless something really weird is happening with the clutch. Because really, i have hardly any power. And where is the knock sensor? Ive checked everything several times to see if it was something simple like that, and am still kinda hoping it will be so it can be easily fixed, but ive looked over all the lines and wired multiple times.
Cameroonski is offline   Reply With Quote
