Old 10-05-2008, 03:50 PM   #25
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by 1993suprawr View Post
also my rpm's only go to 8 is that the highest i can go or is that only cause its stock? and around how many rpm's do the turbos actually kick in?
The oem TT, in sequential mode (that's how they come stock) kick in at about 2250 rpms. The second 'stage' kicks in at about 3500 rpms.
If you upgrade to a big single turbo, then the bigger you go, the later it'll spool in the rpm band.
The oem rev limit is 6800. With an aftermarket (standalone) ecu, you can set your rev limit to whatever you want - like (for example) 7500rpms with the oem valve springs, or (again, for example) 9000+ rpms with aftermarket dual valve springs and a built bottom end.
Life begins at 30psi.
