Old 04-02-2008, 03:09 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Twin Turbo '95 View Post
damn. and here i thought a aftermarket piston would hold up a bit better..
i poked around and read a shit load of topics(again.. read all of them )
TO4R.COM
ok he says what happened. hose of the wastegate popped off...
In other words, he ran too much boost for the octane of fuel he had in the tank. I'd bet any money that if he'd have been running pure 116 octane race fuel, his engine would have been in perfect condition afterwards. My guess is that he was probably running pump gas...
...TO4R.COM
he didnt say what happend.
IMHO. i think it would be something too do with the heat in the desert.. pre ignition...
Although external heat is a factor, the engine won't pre-ignite or detonate even on the hottest day, if you're running a sufficient octane level to match the boost level.
...TO4R.COM
he ran a bit lean. ...
Yep bad tuning will kill you every time. For what it's worth, I already mentioned this in post#2, above.
...NOTE: they all had a piston 6 meltdown. not any other. 3 guys. same pistons. different reasons. imho. I think that if i get the fueling right for the #6 piston then it'll be ok once i start modifying it
You're sort-of on track. The problem is not the fact that #6 isn't getting enough fuel. The problem is that #6 is getting too much air, because the oem intake plenum is not designed for high boost (eg. 750rwhp+). This is why all big turbo'd mkivs run aftermarket intake plenums (along with race fuel, and proper tuning).
Life begins at 30psi.
