Old 01-10-2006, 01:01 PM   #1
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
lol more than likely we're talking bout the same thing
and good plan walkin in with the diagram hehe
k here's all possible water leaks on that side of the engine
  1. gasket which thermostat rear housing bolts to on the head
  2. block off plate on turbo (no pipes go to this one)
  3. water lines to the turbo from thermostat housing
  4. main water union located in center rear of head
  5. top of 90 degree hose going to main water union
  6. hose clamp closest to bottom of thermostat coming from turbo water lines
  7. banjo bolt that bolts into the lower rear of thermostat housing
  8. bottom of 90 degree hose going to main water union connecting to main water pipe
  9. flange/gasket bolts directly to back of water pump/front timing cover connects main water pipe to thermostat
  10. 90 degree hose that always blows out and takes agessssss to even get to located behind thermostat connecting to main water pipe
  11. other side of 90 degree pipe connecting to bottom of thermostat
  12. lower radiator pipe connecting to front plate/timing cover
if you need anything explained more in detail i'll be happy to help out
Pics of my build.
Do a diagnostic first!
