Thread: 7mgte deal
Old 01-17-2005, 10:11 AM   #1
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
to be honest i wouldn't know the current prices of 7mgte's in aus... we buy all our stuff here in new zealand
just keep shopping around and see what other shops quote you
try supraforums.com.au they may be able to help you out
http://www.adelaidejap.com.au/toyota.htm
just make sure that your radiator is higher than any other point of your car... so the radiator is top most... so radiator filler is higher than the engine
so jack her up till she's about that height
now... bhg stuff again lol
what sort of intake do you have on ur car.. is it stock? if so try changing your filter... that may be an attribute to your gutless issues...
don't drill the hole in the thermostat just yet... i don't believe that's your problem.. have you changed your radiator cap at all? or is it a crappy old one lol
in my opinion... don't put a flush thru your engine... if it is worn and got lots of gunge build up the flush may not clean it out of the engine.. rather just move it around and clog up things
do a block check to find out if there are exhaust gasses in your water
local mechanic should have this or local parts store... takes bout 10mins to do
let us know how you go after this and i'll think up some more radical ideas
Pics of my build.
Do a diagnostic first!
