Old 10-21-2005, 08:02 AM   #1
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
does the car make a squealing noise when cold?
it could be a few things... check to make sure two vacuum lines are still going to the power steering pump, when looking at the front of the engine it is located to your left bottom.. there is a little black object with two nozzles on it... it should have two vacuum lines going to it
does your powersteering fluid need topping up (reservoir bottle is on passengers fender beside air filter)
when the car isn't going (off)... go and twist the belt on the power steering pump, how much can you twist it? more than half turn?
Pics of my build.
Do a diagnostic first!
