Old 04-03-2012, 06:28 PM   #10
Grandavi
Grandavi's Avatar
Originally Posted by Doat91 View Post
What do you guys think of a 91 mk3 turbo targa top 5spd everything in excellent condition, motor is fine, interior is great, tranny is fine, 80k original miles, only damage is the scuff and hole in the front bumper and a small ding behind the drive side door for $3,200?
I call that a super deal. Just get the engine looked at closely.. everything else is age/wear and tear. Plus.. it all depends on your plans for the car.
Make sure you put your hands down the rear quarter panels (there are access panels in the hatch area) and check the condition of the metal along the wheel wells and inside the quarter panels. Dirt+Water = rust holes which will eventually pop off the quarters if not given attention asap. Water can also come in via the brake light seals and hatch seal, but that usually lands up in the spare tire well (which you need to see WITHOUT the spare tire). A bit of blue from a cold engine start can mean a simple valve seal shrinkage which is common for the 7M engine.. and normally I wouldn't say this, but I have had 3 gas tanks leak so far, so it would be nice to see it with at least 65% fuel in the tank.
3200 is a good buy if the car is fairly straight and runs nice. Its repairs which can kill you financially depending on your level of expertise.
Good luck!
