Go Back   Toyota Supra Forums! Join the Supra forum! > General Discussions > Supra FAQ
Old 05-03-2009, 08:07 AM   #11
mikkey9289
mikkey9289 is on a distinguished road
I Don't understand why you are complaining about the oil filter. I have changed the oil on my 7M's Turbo and NA multiple times, and all I can say is "Beats the hell outta doing it on a 2JZ". I have a spring loaded gap style filter wrench i got from the Matco guy here while i worked at our Toyota dealership. I love it. By far the best filter wrench. I would go as far as saying it was worth the 20 bucks it cost me.
mikkey9289 is offline   Reply With Quote
Old 01-30-2010, 04:09 AM   #12
MalumInSe
MalumInSe is on a distinguished road
Originally Posted by supertoyota View Post
Does anybody know about the Quick Oil Drain Valve?
www.qwikvalve.com
I will probably get one for my vehicle. However, if somebody has already installed and give me more info for the item, I would really appreciate it.
Don't waste your time with that crap. You are just asking for something to go wrong. Keep the regular drain plug.
MalumInSe is offline   Reply With Quote
Old 01-30-2010, 07:01 PM   #13
There's not much about the design that leaves it open to failure... other than bottoming out just right and ripping it and a chunk of the oil pan out. Myself, I stick with bolts, but I know a few people (including a couple mechanics) running these and not one has had a problem yet.
Old 01-31-2010, 02:02 AM   #14
shoot. you go into it blind once and it takes an hour. 5 minutes every other time. I do remember me cursing the firs time I removed my oil filter. like "wtf? its suposto to come out where!?!?" clank! nope.. Clank, NOPE!
just associate it with learning to tie your shoes.. the rabbit comes outa the hole, makes a loop, runs around a tree.... over some pipes gets oil in his eye, bangs his head... you get the idea.
Old 04-14-2010, 03:49 AM   #15
87mk111
87mk111's Avatar
i usuaully use the K+N filter so I can use a wrench to get it off.
Change the climate cntrl color? XtreeX MKIII Supra 6 05-10-2008 01:54 PM
Speedo is out, what do I change? linuxgurupodboy Non-Generation Specific Questions 0 05-15-2007 12:07 PM
my mkiv supra wont start after engine change HELP!! gkhawk MKIV Supra 1 08-18-2006 12:40 PM
spark plug change supfoo514 MKIII Supra 4 06-30-2006 07:41 AM
Should I STILL change head gasket?? lifesnotfair MKIII Supra 7 01-13-2006 01:08 AM
