Old 08-06-2007, 09:37 PM   #1
D_Train
D_Train is on a distinguished road
Originally Posted by cageceo
Rofl, that was funny as heck to me.
wow i Read it all, well so far i got this great brand of car soap im pretty happy with it. also got the micro Fiber Cloth's about 10 new still in the bag. wanted to know can i re use them ?? if i wash them or do i have to buy new ones each time i choose to wash my car which is usally every other weekend.
You rock man i really appreciate you taking the time to write all of this. Take it easy and hopefully you finish before this weekend so i can test it out and let you know how it Goes for me.
Yup, i'll finish it in time for the weekend. Hopefully i'll finish it today or tomorrow night at work. And please ask tons of questions, no matter what they are, when I was learning i asked SOO many questions that I thought were dumb but I needed to know so I didn't screw up. So ask away!
Inresponse to your questions, you can reuse your cloths, and here some people will tell you different things, but here's my opinion: If the cloth is clean, use it. i.e. if theres no visible dirt and no product wiped off on it, you can use it. I find the best thing to do is fold it in quarters when using it, because then you get a bunch of different sides to work on (you just keep folding it differently and flipping sides). Otherwise just wash it in your dryer. The ones that you wipe the wax off with you might want to hand wash so you dont f*ck up your washer/dryer, but i don't do much laundry so I donno if in fact you can wash/dry that stuff with machines. If it were me i would buy some more cloths (edit: i mean more than 10, you do not have to buy more cloths each wash) . They aren't the most absorbent things but they are so good to your paint so thats kind of the trade off. I used to run out of cloths when drying my car from the preliminary wash so thats why i've accumulated so many.
"Also in which order do i do the Clay Bar and the Scratch X ? "
Use the clay bar and THEN the scratch x. But you can use scratch X by itself w/o using the clay bar at all. The clay bar will get almost all the dirt off your car (you'll be suprised how much dirt gets on the clay while you are working) and i forgot to mention when using the clay bar, you will see it start to turn brown from dirt, just re-kneed it until you get a clean spot on the clay and continue. remember to keep it moist with the quick detailer that comes with it. The Scratch-x essentially takes off a MINISCULE (so so so super small) layer to get rid of the scratches. It is not bad for your paint and is also better than those other scratch products because all those do are fill in the scratches where scratch-x will permanently get rid of them (provided you wash your car properly)
The clay bar you can do once/twice a year depending on how much you drive and how often you wash your car. Scratch-x you can use to your descretion. If you have no more scratches, switch to this other paint cleaner.
because if you don't have any more scratches there is no more point to the scratch x.
Again, do the clay bar before the scratch-x. But both don't have to be used on every wash. You will want to eventually switch to the regular paint cleaner.
D_Train is offline   Reply With Quote
Old 08-06-2007, 09:40 PM   #2
fulljapan
fulljapan is on a distinguished road
someone sticky that* post!
fulljapan is offline   Reply With Quote
Old 08-07-2007, 08:26 PM   #3
D_Train
Ok, so we've covered the basic wash and clean so far. I have been recommending Meguiars products but I hate to sound like a broken record and if you have a product that you like better or that you want to try, by all means try it. Some paint will LOOOVE one product and other paint will only get so/so benefits from it. Meguiars is all around pretty good for most paint so thats another reason why I keep using it.
Ok, so onto the polish.
We are going to be polishing by hand to start out with. After some experience I would recommend going out and purchasing a polisher. You will get a MUCH better polish with an orbital polisher, but don't worry. you will still get a niiiiiice clean finish by hand as long as you do things right.
Don't just jump to a polish after you wash your car. Its easy to be impatient (believe me, I was) and just itching to get that paint shiny and glossy. you have to make sure your paint is clean. Thats why we go through the first two steps before polishing.
This is the polish I use
Now, with this it is recommended that you get a slightly different applicator
It is a little gentler and will apply the polish very well. You can use a regular applicator pad with this product if you want though. It won't be the difference between a good job and a shitty job, but you will be able to tell a slight difference.
It's going to be the same old story with this, put some polish on the applicator pad and start with a section of your car. You want this stuff to sit for just a little bit. Maybe a few minutes after you are done applying it to the paint. there is no need to work it in super hard, the polish will come when you buff it out with your microfiber cloths. So to reiterate, apply the polish on an area and let it sit for about a minute. Take your microfiber cloth and buff out the area that you applied the polish. Go in circles with your cloth and you can press somewhat hard if you want. The polish is also designed to reduce the look of scratches so you don't run the risk of scratching your paint with a little too much force. Don't go conan the barbarian on it though.
Polish the rest of the car. If you so desire do it again, right after the first run through. at this step you can see the end of the tunnel so its hard for me to polish again, but if you want picture perfect don't skip the second run-through.
Wax
You're ALMOST DONE!!!!
I think this is the easiest step. Use a regular applicator pad and twist it around in the wax. Apply it to your car. Its hard to describe the amount that you want on your car. You will just get used to it by doing. the first time i did applied wax it looked good. Then after it dried and I tried to buff it off I discovered it was WAYYYYY too much and was really hard to buff out. again this will be a learn-by-doing step, but don't get intimidated b/c you can't screw it up, its just that if it is too thick, it will be hard to buff out.
Anyway, sorry about that tangent, you will be waxing your entire car at one time. the wax is supposed to dry. hopefully your car is still in the shade or in your garage. Apply and even coat of wax to your entire car. don't worry if you get it on the trim and stuff it won't hurt it, and you can clean it off later. I have had times where i get wax on parts of the car and its a b*tch to get off, but it has always come off in the end. after you apply wax to the whole car, make sure it has dried and come back with a clean microfiber cloth and buff off the wax. I hate doing this b/c i have weak arms (lol) but after a little while all the wax will be off. then you should wax again (especialy if you havn't waxed in a while).
You don't have to wax your car every time you wash it. Maybe once a month or every 6 weeks depending on how anal you are about it.
Almost almost done now.
After the wax is off, go over your car with another set of eyes to see if you missed anything. There will definitly be a spot here and a spot there that you didn't wipe off or that has a smudge or two on it. your windows by this time will be all smudged up from you putting your weight on it so you don't have to touch your car with your hands. Just get a good glass cleaner for the way end and clean off your glass. I like stoners in the aerosol can:
Some of the glass cleaner will prob. get on your paint, so just keep a clean cloth handy to wipe it off.
Tires: Any tire shine is fine. The gel stuff will last the longest.
Rims: This product sounds really cheesy, but it worked wonders for me and I didn't even scrub with a brush. With a hard bristle brush your rims will be clean. Maybe not shiny, but there will be almost no dirt, it works great!
Congrats! your car is damn pretty. Please ask questions. I am terrible at explaining things and the more questions asked the clearer the message will be.
Old 08-07-2007, 08:35 PM   #4
D_Train
if you have been reading along i made some edits in the first post to watch out for.
Old 08-07-2007, 09:11 PM   #5
fulljapan
My first impression is: holy sh*t, that's a long trip! I have seen the pictures of your car, shiny like a medal, but do you have any other?
Do you sometimes wash your car in a shorter lapse of time? Like by just keeping the basic steps.. if yes it would be nice to know wich ones
Old 08-07-2007, 09:16 PM   #6
D_Train
Sometimes i'll just wash it and dry it if i have some freetime on a sunday or some day after work. Especially if i just went though all the detailing garbage, a wash is all that the doctor ordered. I just make sure I dry it properly. And my windows get fucking dirty so quick i hate it, so i usually end up cleaning those.
The have this product "wax as you dry" I forgot from which manufacturer. I've seen it at walmart and auto stores. Essentially you do what the product is, you spray it on your wet car, and as you dry it, it will shine and wax it.
But essentially when I detail my car it will take 8-12 hours depending on how anal I am and if I do the inside or not.
When you say "do you have any other" do you mean any other cars? Or any other pictures?
Old 08-07-2007, 09:35 PM   #7
fulljapan
Excuse me for my bad english, I originally speak it's opposite language :P
Do you have any other pictures?
1990 Supra Vs. 2002 Wrx Vs. 2001(ish) Mustang GT Junkyard_Dog Off Topic Forum 2 07-28-2011 06:00 AM
Mustang guys are so ignorant!! Isphius Off Topic Forum 13 12-25-2006 03:29 AM
Supra 1986.5(non turbo) VS Mustang 1996 Supra GuestBarbotte Non-Generation Specific Questions 4 03-19-2005 03:35 PM
