Old 12-20-2006, 09:27 PM   #1
whitequasimodo
whitequasimodo's Avatar
whitequasimodo is on a distinguished road
Default whitequasimodo "AZ;CA" 88 turbo
hi here pics of my supra. im going to get my bottom end done soon "next month." also there no mods but when i take the motor out im going to put
1.Supra Cam Gear by Unorthodox Starting At $365.16
2.Supra Crankshaft by Toyota Starting At $769.00
3.Supra Main Bearing by Clevite Starting At $65.50
4.Supra Oil Pump by Toga Starting At $217.19
5.Supra Piston Ring by JE Starting At $111.06
6.Supra Rod Bearing by Toga Starting At $90.31
im doing the oil pump cuz my oil presure between 40 and 0. the middle line. and so its burning oil. hope you like it.
also there be a pic of me and my girl.
click to make bigger
whitequasimodo is offline   Reply With Quote
Old 01-05-2007, 03:23 AM   #2
whitequasimodo
what do you guys think
Old 01-06-2007, 08:05 AM   #3
ARZ
ARZ is on a distinguished road
Why do you need to buy a crank? Just check and see if yours is straight and have it balanced.
Also make sure you do Rods and Pistons.
BTW where in AZ?
89 Turbo 5 Speed hard top
1971 240 Z, 7MGTE, 5 speed, 487 RWHP @ 23 PSI, weighing 2505 lbs.
www.ArizonaPerformance.com
ARZ is offline   Reply With Quote
Old 01-06-2007, 05:37 PM   #4
whitequasimodo
BTW where in AZ?
litchfield pk
i am going to redue everthing inside if its ok than ill take a look on if i should replace it or buy you know
Old 01-06-2007, 05:55 PM   #5
ARZ
Yea the cranks are bullit proof, Im building my motor over the next few weeks I will probbably post pictures when Im done. I had my crank polished it looks bitchen.
Old 01-09-2007, 05:17 AM   #6
whitequasimodo
well i got my engine out and ill also take some pics on how i did. also ill take pics on whats im doing.
Old 01-16-2007, 01:50 AM   #7
whitequasimodo
well this crank was not bullet proof. i had a connecting rod snap in half, but did no damage to the block. it did though put in some deep scratches in the crank. what im going to do is get bottom end machined and get a new crank. as for my connecting rods im going to get oem all new.
Old 01-16-2007, 02:13 AM   #8
ARZ
I got Eagle Forged cranks for less than $500 bucks.
Old 01-16-2007, 03:53 AM   #9
Murd
I think you look more like WhiteKomodo than WhiteQuasimodo! j/k
Seriously tho, nice start! While you have the engine out, you could get a fidanza flywheel too!
Old 01-16-2007, 04:34 PM   #10
whitequasimodo
all ready started getting new parts
ACT Supra 86-92 Heavy Duty Pressure Plates - Turbo
Fidanza Supra 86-92 Built To Fly Flywheels - 3.0L, Turbo (7M-GTE)
HorsepowerFreaks Supra 86-92 Bronze - Supra MK3 Turbo Clutch Disks - 5 spd Turbo (Sprung hub) 21 spline 235mm
Toyota Supra 86-92 Accordian Air Intake Hoses - Turbo
now just have to find out why my turbo has oil all in the intake...
one more thing does anyone know where i can get a blockoff plate on the tran. when i got my supra it did not have one and i dont want crap flying into the flywheel and get stuck in the hole....
