Old 12-20-2006, 09:27 PM   #1
whitequasimodo
whitequasimodo's Avatar
whitequasimodo is on a distinguished road
Default whitequasimodo "AZ;CA" 88 turbo
hi here pics of my supra. im going to get my bottom end done soon "next month." also there no mods but when i take the motor out im going to put
1.Supra Cam Gear by Unorthodox Starting At $365.16
2.Supra Crankshaft by Toyota Starting At $769.00
3.Supra Main Bearing by Clevite Starting At $65.50
4.Supra Oil Pump by Toga Starting At $217.19
5.Supra Piston Ring by JE Starting At $111.06
6.Supra Rod Bearing by Toga Starting At $90.31
im doing the oil pump cuz my oil presure between 40 and 0. the middle line. and so its burning oil. hope you like it.
also there be a pic of me and my girl.
click to make bigger
whitequasimodo is offline   Reply With Quote
Old 01-05-2007, 03:23 AM   #2
whitequasimodo
what do you guys think
Old 01-06-2007, 08:05 AM   #3
ARZ
ARZ is on a distinguished road
Why do you need to buy a crank? Just check and see if yours is straight and have it balanced.
Also make sure you do Rods and Pistons.
BTW where in AZ?
89 Turbo 5 Speed hard top
1971 240 Z, 7MGTE, 5 speed, 487 RWHP @ 23 PSI, weighing 2505 lbs.
www.ArizonaPerformance.com
ARZ is offline   Reply With Quote
Old 01-06-2007, 05:37 PM   #4
whitequasimodo
BTW where in AZ?
litchfield pk
i am going to redue everthing inside if its ok than ill take a look on if i should replace it or buy you know
Old 01-06-2007, 05:55 PM   #5
ARZ
Yea the cranks are bullit proof, Im building my motor over the next few weeks I will probbably post pictures when Im done. I had my crank polished it looks bitchen.
Old 01-09-2007, 05:17 AM   #6
whitequasimodo
well i got my engine out and ill also take some pics on how i did. also ill take pics on whats im doing.
