Old 06-15-2006, 12:32 AM   #1
Supra2NR
Supra2NR's Avatar
Default wind splitters
to anybody that cares
about a week ago, in a jacked up thread, i was asking pple what would b a good idea to use a wind splitter
these things are usually made out of carbon fiber
but those things costs about 2-300 hundred dollars
i dunt have that money, and if i did it will go to the engine
so i came up with a backyard solution in case anybody wants to do it too
all you need is a piece of wood, metal file, and sanding paper, and bondo in case you make a mistake
im not done with it yet, but sumbody askd me to post sum when i start doing it
it might look crappy now but it'll look better after finish and when its mounted
Old 06-15-2006, 03:55 AM   #2
burton51m
burton51m's Avatar
Post too early to tell
this looks good so far but too early to tell. you know that you can actually make your own carbon fiber... they sell it at your local marine(boat) shops and other places.look around. if you didnt already know its a mesh fiber mixed with epoxy. it could majorly strengthen your lip!
it doesnt look as good as regular carbon fiber but you can probably paint it
just throwin out ideas
Old 06-15-2006, 04:22 AM   #3
Supra2NR
Supra2NR's Avatar
question: how can you layout carbon fiber tho? is it hard work to make it ? can u describe the procedures that you have to do
well as the splitters go, they're not halfway done yet, itll look good once its finishd and painted, its a challenge since the sides of the bumper angles up
so maybe ill use the wood as a pattern when its done then ill get the carbon fiber. what do i need to tell shops when i go lookin for it? any brands? names?
Old 06-15-2006, 04:27 AM   #4
damdog05
damdog05's Avatar
what exactly is the purpose of these wind splitter?
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
Old 06-15-2006, 04:36 AM   #5
Supra2NR
Supra2NR's Avatar
lessen wind resistance, and to bring more wind to the inlets
Old 06-15-2006, 06:51 PM   #6
burton51m
burton51m's Avatar
it is sortof hard to make and you might need someone elese to help you
-the first thing you do is lay the fiber mesh stuff out and have someone hold it for you where you want it on your lip.
-mix the epoxy...you'll need a lot for your lip.
-spread the epoxy all over the fiber and cover it all. dont forget to get the edges of the fiber so it dosent peel. the epoxy will seep into the fiber and create a strong bond. let it sit over night.
- if you mess up a little dont worry because you can always sand it down and fill the parts in with more epoxy.
if you want to save money you might want to put carbon fiber only on the front or tip of your lip since it will be taking the most beating, but covering the whole thing is fine too.
when you attach the lip to your bumper you can drill through the carbon fiber or you can make pre drilled holes
Old 06-16-2006, 09:51 PM   #7
Supra2NR
Supra2NR's Avatar
Default its done!!!
kinda of a botch job since im rushing today, cuz its race day here
this thing took two days of my life away from me, lucky i had carpentry experience kinda helps a lot with this type of project
painted it white so it'll match the body
ID:	308   Click image for larger version
ID:	309   Click image for larger version
Old 06-18-2006, 05:51 AM   #8
theWeezL
theWeezL's Avatar
I might be mistaken, but Im pretty sure your just talking about fiberglass, not carbon fiber...Carbon fiber is made by superheating a cabon impregnated mesh, melting the cabon and causing it to re-align on a molecular level creating extremely strong and light solid material.
Ive worked with fibergalss before, and while its harder to work with than bondo, its stronger and more flexible. It is however, NOT carbon fiber...
Actually Sup'2NR, those look better than I pictured in my mind...dont skimp in the end, go the extra mile on em. make em look factory good and get us all to oooh and ahhh, hehe
____________
Old 06-18-2006, 05:08 PM   #9
Supra2NR
Supra2NR's Avatar
i thought i was right, cuz i never heard anybody using epoxy with carbon fiber,
fiberglass version of the splitter is on the way , this was basically a trial, and a pattern basically now, i got the shap, i got the mounting holes,
everybody can expect a more slick profile next time around, and im thinking of molding it to the front bumper
anybody took thier front bumper off? got a write up share it please
Old 06-18-2006, 07:54 PM   #10
burton51m
burton51m's Avatar
youre right... my friend has it and calls it carbon fiber i guess b/c it looks similar to it. they use that stuff on boats to fix the cracked hulls which are also fiberglass which makes sence now why they would be selling it at boat shops.
I didnt mean to make it seem like it was "actual" carbon fiber. i just called it that.
