Go Back   Toyota Supra Forums! Join the Supra forum! > Private Classifieds > Parts Wanted
Old 09-10-2015, 12:44 AM   #1
A.BuckShort
A.BuckShort is on a distinguished road
Smile Need ECU (ECM) replacement for 1993 Supra 2JZGE
Non-turbo, auto trans., fed. emissions. OM PART # 89661-14580
Understand interchangeable with same configured 1992-95 Supras, 1992-05 Lexus 300s (and possibly Lexus 400s)? Is that correct? If so would the Lexus units have same OM part # 89661-14580?
Current core cannot be rebuilt because problem is fuel pump signal/circuitry issue. Have replaced fuel pump, fuel pump designated (smaller) ECU, cleaned throttle. Sent core to Philly for rebuild and return. Came back “ECU cannot be repaired.”
If all else fails have workaround option of running fused wire direct from ignition to fuel pump -- with current ECU also reinstalled (still seems to work for all other functions). But would prefer to first try to just replace this main ECU with a working unit including for fuel pump issue.
Seller offers, leads on available units, sellers, where to look also appreciated.
I really appreciate this forum. Thanks.
Roger Burke
I can also be emailed directly at reb1000@sbcglobal.net.
A.BuckShort is offline   Reply With Quote
Tags
1993 (92-95) supra, ecm, ecu, lexus sc 300-400
2jzge mk3 supra swap electrical issue Jordanc MKIII Supra 0 02-02-2015 04:01 AM
Wheel bearings for 96' Supra SZR 2JZGE Alfa_Zulu MKIV Supra 4 09-14-2011 10:39 PM
1991 Non-Turbo Supra - Power Antennae Replacement Options unkymurch Non-Generation Specific Questions 2 04-29-2007 06:35 PM
