Old 01-09-2006, 05:02 AM   #1
dcrusupra
dcrusupra's Avatar
Default Friends 92 celica
My friends 92 celica vibrates like hell when its idling. It gets a little better in neutral and it gets a little better if you turn the a/c off. and it stops vibrating when you start driving. any ideas?
New Rebuild
My CarDomain
Old 01-09-2006, 06:41 AM   #2
Bullz_EyE
Bullz_EyE's Avatar
Bullz_EyE is on a distinguished road
A tune up.
Bullz_EyE is offline   Reply With Quote
Old 01-09-2006, 09:23 AM   #3
kewlcoconut
kewlcoconut is on a distinguished road
change the plugs
ie. tune up
kewlcoconut is offline   Reply With Quote
Old 01-09-2006, 03:40 PM   #4
Bullz_EyE
Bullz_EyE's Avatar
Considering it's age, I'd give it a tune up a little more thorough than that. Spark plug wires, cap and rotor, spark plugs, fuel filter, an intake "cleansing", such as the use or combination of a can of throttle body cleaner (I use Valvoline), B-12 ChemTool Total Fuel System Kit, or SeaFoam, and a good fuel system cleanser to pour in the tank.
Do this all at once when the car is ready for it's next oil change. I also recommend an engine flush. You can also take it a step further with the flush too. After you do the flush, refill oil with an inexpensive brand, minus one quart, and substitute it with a quart of ATF. Drive 50-100 miles then change the oil again to the usual brand.
DO NOT USE THE ATF TECHNIQUE ON TURBO CHARGED VEHICLES.
Old 01-09-2006, 06:55 PM   #5
dcrusupra
dcrusupra's Avatar
I did forget to mention, the car only has 40,000 miles on it.
New Rebuild
My CarDomain
Old 01-09-2006, 08:27 PM   #6
Bullz_EyE
Bullz_EyE's Avatar
Regardless of miles, some of those components are simply old.
Old 01-10-2006, 02:59 AM   #7
mrnickleye
mrnickleye's Avatar
^^Yep, I see this problem every day at the shop. I suspect that the intake system has some carbon build up. Do the intake cleaning like mentioned above, THEN put in new sparkplugs, and oil change.
Also the fuel injectors are probably dirty, and possibly leaking. Thats may be why it runs better once you drive it.
Old 01-10-2006, 04:00 AM   #8
Bullz_EyE
Bullz_EyE's Avatar
Forgot to mention that order. You don't want to foul your new plugs. Good catch.
Old 01-10-2006, 10:52 AM   #9
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
is it automatic?
Pics of my build.
Do a diagnostic first!
Old 01-10-2006, 05:25 PM   #10
dcrusupra
dcrusupra's Avatar
Yea auto, u r psychic suprra_girl. And mrnickleye, how can i tell if the injectors are leaking, if that is the case?
New Rebuild
My CarDomain
celica supra engin conversion supramadness MKII Supra 3 04-10-2006 12:00 AM
