Old 04-08-2009, 01:08 AM   #1
suprabahamut
Default 2 Cylce oil question
It is an educated question that I wanted to ask some of you guys. A while back I had a RX7, and I would run 1 ounce of 2 cycle oil with every 2 or 3 gallons of gas. Some say it lubricates the apex seals better, and some say don't do it. Only reason I used it was, because my friend has had 3 RX7's and is a rotary mechanic and he uses it, so I thought if a rotary mechanic tries it it must be okay. So I wanted to know if it worked on a rotary engine What will happen in a piston type engine? Would it hurt any thing to run a little 2 cycle oil in a blazer, or an old Cadillac? I thought it might help restore compression, like when you put some oil in the spark plug hole when compression testing.
Old 04-16-2009, 04:03 AM   #2
burton51m
burton51m's Avatar
I wouldnt mess around with putting oil in your gas and stuff like that. just get some engine restore
http://ecx.images-amazon.com/images/...500_AA280_.jpg
Old 10-16-2010, 09:35 PM   #3
bioskyline
bioskyline is on a distinguished road
if your engine is burning oil, i fill the crank with 2 stoke oil, smokes a lil less and doesnt foul the plugs as fast.
87 silver turbo targa, bone ass stock (for now)
bioskyline is offline   Reply With Quote
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
Help! Question on front NOSE and bumper supports. lifesnotfair MKIII Supra 1 12-26-2005 03:54 PM
Quick question AutoXMan MKIII Supra 12 09-30-2005 06:40 AM
