Old 05-23-2005, 02:13 PM   #1
Black 5spd
Black 5spd is on a distinguished road
i have just joined the supra owners club, i got my 86.5 5spd on wednesday.
i have to change the cluch master cylinder, how would i do that????
and i cheched the oil the other day and it was just on the TIP of the dip stick, WHERE DID IT GO? it was not in the ground.
and the top of the gas tank leaks how do i fix that???
thanx.
Black 5spd is offline   Reply With Quote
Old 05-23-2005, 09:34 PM   #2
monkihead
monkihead's Avatar
it could either have burned it, or have leaked it out on the road on higher rpms. ie-low rpms have low oil pressure compared to higher rpms.
monique- better off dead
Old 05-24-2005, 11:01 AM   #3
GET OIL IN THERE ASAP
you don't want rod knock
can you see any oil on the underside of the car? as stated above it could be leaking out at higher pressure
does the car smoke at all when driving?
and i would suggest that you get a friend or mechanic to do your clutch for you... removal is easy for someone new to cars... but bleeding a clutch is not so easy and requires two ppl anyway
good luck with the car.. and keep up the maintenance
Old 05-24-2005, 01:38 PM   #4
supersupra
supersupra is on a distinguished road
not bad suprra girl, not a bad win at all, both being tt 6's. Never came to mind that they actually were in the same league, 300zx big an all :lol:
supra+girls+happiness=<span style='color:blue'>A LIFE</span>
supersupra is offline   Reply With Quote
Old 05-24-2005, 01:45 PM   #5
lol
i run a 7mgte... one turbo lol
300zx similar weight to mk3... being 2wd and turbo we go in the same class
and not forgetting he was running bout 16psi and i was running a huge amount....... 9psi LOL
i got the hell launch on him and beat him all the way down woot woot haha, that's the most recent pic i have of me going down the strip but my best time is actually a 13.3 full trim
How hard is the clutch master cylinder to replace? the#1 MKII Supra 2 05-27-2016 04:32 AM
Clutch Master Cylinder question. 1989 Supra. PFlanagan MKIII Supra 4 08-07-2008 08:20 PM
