Old 04-17-2007, 02:42 AM   #1
dannydavi
dannydavi's Avatar
Default Welding the differential???
Originally Posted by thechori
from you guys' experience with this car, what would you say was the most neccesary thing to drift the car properly? i'm looking into drifting my '89 N/A as well, but i'm kinda skeptical b/c it's my daily driver as well, and supras aren't cheap to fix :[
Originally Posted by MARKPRIOR
Most neccesary thing would have to be to stiffin the chassis and weld the diff, or you could shim the diff if you dont want it permenantly locked
hey guys i just wanna know what exactly does welding or shimming the differential do? Does it make it to where both wheels spin as opposed to just the one that does on ours? any help is appreciated
and how much work is involved in doing that process assuming i knew how to weld? thanks in advance
ps. this may have more hits in the drift category, wasnt sure.
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 04-17-2007, 03:15 AM   #2
Wink
You DO NOT want to weld your spider gears in the differential.
If you did (and I have done it before, on 4x4 mud puller trucks), you could NOT drive the car on pavement.
Shimming is for LSD diff. It make it tighter than stock, but not good for a daily driver car. And, a bunch of work that you, or whomever does it, better know what they are doing.
Old 04-17-2007, 01:51 PM   #3
IHateHacks
IHateHacks's Avatar
Get an LSD diff out of a mk3 turbo supra. All turbo supras came with an LSD. N/A's didn't.
Old 04-17-2007, 07:26 PM   #4
dannydavi
dannydavi's Avatar
would that explain why sometimes only my right rear wheel will spin, as oppose to both?
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 04-17-2007, 07:39 PM   #5
Supra2NR
Supra2NR's Avatar
Yep, but unless you won't drive ur car on the street anymore, don't weld it, next thing that you're gonna break is an axle,
Jus get the diff from a turbo mk3
Old 04-17-2007, 07:58 PM   #6
dannydavi
dannydavi's Avatar
Ah i see, thanks for the input. So turbos have LSD and N/A's do not, i was unaware of that.. good to know
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 04-17-2007, 08:26 PM   #7
Supra2NR
Supra2NR's Avatar
I had an NA with lsd, I only said look for a turbo mk3 since your more likely to find an lsd on a turbo one rather the na
Old 04-17-2007, 10:05 PM   #8
dannydavi
dannydavi's Avatar
oh, so now how would you depict the two?
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 04-18-2007, 04:47 AM   #9
Supra2NR
Supra2NR's Avatar
the easiest way to find out if a car has lsd without opening anything
is to put the rearend on jacks and spin the tires if the other one spins to the same direction as the other one, then it has a lsd
Old 08-21-2009, 05:52 AM   #10
89supraHo
89supraHo is on a distinguished road
so do all mk3 models have lsd ? i know u might not agree witha welded diff, but i have been told haveing a welded diff may help me drift better. and driveing on the streets no prob. i see nissan 240's use them as a daily and drift.
89supraHo is offline   Reply With Quote
differential swap or not kkiepvvessau MKIV Supra 22 09-02-2008 01:55 AM
MKIII Differential SupraSleuth Non-Generation Specific Questions 3 08-06-2008 02:44 AM
limite slip differential suprabahamut MKIII Supra 0 08-22-2007 04:08 AM
Welding TRAFIK Off Topic Forum 4 07-26-2006 06:00 PM
Differential gearing changes? jibbby MKIV Supra 0 02-23-2006 07:51 PM
