Old 12-08-2009, 08:52 AM   #11
riojohn
riojohn is on a distinguished road
HI,
Most 240sx’s come equipped with what is called an open differential. An open differential is designed with four gears set inside a casing that is rotated by the driveshaft. One gear connects to each output shaft and the remaining two gears connect to a center pinion and rotate in opposite directions perpendicular to the rotation of the casing.
In this manner, power can only be sent to one wheel at a time because the pinion gears counter the rotation of the casing for one output shaft at a time. In short, one wheel gets power while the other one coasts.
Thank you....
riojohn is offline   Reply With Quote
differential swap or not kkiepvvessau MKIV Supra 22 09-02-2008 01:55 AM
MKIII Differential SupraSleuth Non-Generation Specific Questions 3 08-06-2008 02:44 AM
limite slip differential suprabahamut MKIII Supra 0 08-22-2007 04:08 AM
Welding TRAFIK Off Topic Forum 4 07-26-2006 06:00 PM
Differential gearing changes? jibbby MKIV Supra 0 02-23-2006 07:51 PM
