Old 04-08-2007, 01:44 AM   #1
ojb24
ojb24 is on a distinguished road
Default Please Help!!
Hello, I have a manual 1987 supra turbo that keeps choking. It'll start up
with no problems and idles fine, but when I put it in any gear and drive
past 2,500 RPMS it will choke. I can never go past 2,500 rpms. Can anyone
tell me whats is wrong with my car? thank you
ojb24 is offline   Reply With Quote
Old 04-08-2007, 06:26 AM   #2
Check the FAQs section for how to diagnose codes.
One thing that can cause the problem you say is....a plugged exhaust.
Old 04-08-2007, 11:35 AM   #3
ojb24
Thats what I had thought but I've already checked the exhaust and that wasnt the problem.
Old 04-09-2007, 05:43 PM   #4
Supra2NR
Supra2NR's Avatar
Does it sputter when you go past 2500
Can only depress the pedal at a certain point b4 it chokes and dies?
Can the car still move until you past a certain throttle point?
If you answered yes to all the questions
You might have the same problem that I had
There was a wire on the afm which got cut
So my suggestion is check all of your wires and check the afm plug if it properly secured
Let us know what happens
Old 04-09-2007, 07:54 PM   #5
Mr.Luder
Mr.Luder's Avatar
Mr.Luder is on a distinguished road
Are you getting a CEL? (CHECK ENGINE LIGHT)
try getting another ecu if possible and see if it works
Mr.Luder is offline   Reply With Quote
Old 04-10-2007, 03:52 AM   #6
redmaro
Deffinetly not, buying anouther ecu should be one of the last steps you take.
MK3, Auto, Turbo.
Old 04-10-2007, 04:32 PM   #7
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
Default chokeing
when my auto did that it was the TPS so unplug it and go from there if it still does it than its not it.
My 1989 toyota supra mods:83.5 mm bore, ARP main studs, ARP rod bolts,rings, Cometic .060" headgasket, ARP head Studs, Ferra 1 mm oversized valves, port work, Rc 550cc injectors, Walbro 255hp
Turbo: 1.15 A/R T4 twin Scroll turbin - journal .60 A/R compressor, Hallman Pro MBC, Turbo XS Blow-off Valve, 50mm wastegate, hks fcd
Intercooler: 32x12x3 core, 3 inch piping, with clampco t-bolt clamps
Exhaust:Exhaust manifold T4 twin scroll,2JZ 3 inch downpipe Fabed up to fit, Mandrell bent 3in back
Supra_87_mk3 is offline   Reply With Quote
Old 04-11-2007, 07:57 AM   #8
supradad86_5
supradad86_5 is on a distinguished road
I had that same problem after buying my JDM. My turbo was locked up and I didnt even notice before putting in the engine. It wouldnt budge at all, so I wasnt getting enough air for the engine to run at 2500 rpms.
86.5 JSPEC 7MGTE 5SP, 14psi, HKS 2MM MHD, CENTERFORCE ST 2, 3" TURBO BACK, MANUAL BOOST CONTROLLER, JDM INTERCOOLER AND 2.5" HARDPIPES, APEXI NEO, WALBRO 255LPH, LEX AFM, DRILLED AND SLOTTED ROTORS AND RACE PADS, 18" STAGGERED 275/40 REAR, 245/40 FRONT.
NEXT ON LIST: PAINT, JZA70 FRONT BUMPER, CARBON HOOD, RS RACE SPRINGS, POLY BUSHING KIT, SWAY-BARS.
supradad86_5 is offline   Reply With Quote
Old 04-11-2007, 04:22 PM   #9
Supra_87_mk3
does it feel like when you put it in gear and try to go you take off, hit 2500, then dies down and it kinda feels like a rev limiter? b/c that was how mine was with the TPS. post reply please
