Old 03-21-2007, 08:21 PM   #1
doc1
doc1's Avatar
doc1 is on a distinguished road
Default fuel injector issues
Hey all, lets see if u can gimme a hand. I recently finished putin my 87 n/a7m-ge back together after about 6 months and needless to say some of my parts had some weathering issues. But ne ways i was just wandering if ne one knows the sequence of the plugs on the wirering harness right at the fuel injectors, My supra is missen and i cant find out where its comein from so im guessin i might have mixed those up. i have some oil on my plugs also but i thikn i got that taken care of. but ne one got ne ideas ? thx everyone
87 silver/sky blue, UNDER CONSTRUCTION: engine swap to 1jz, headers+3" exahust, toki struts eibach pro kit icw wheels wraped in kumos, light wait driveshaft intercooler walbro fuel pump...
doc1 is offline   Reply With Quote
Old 03-26-2007, 11:23 PM   #2
doc1
doc1's Avatar
Default anyone?
can ne one just take a look for me?? ~~bump~~
Old 03-27-2007, 01:31 AM   #3
IHateHacks
IHateHacks's Avatar
Well I don't know if this is gonna help you but, standing on the drivers side, the injector connectors are color coded and they alternate from white to brown. It starts with white on the injector for cylinder 1, then brown for cylinder 2, white for cylinder 3, brown for cylinder 4, white for cylinder 5, brown for cylinder 6. And its really hard to get them mixed up, since the wiring is very short and I don't think you could connect cyl 2's connector to cyl 1's injector even if you wanted to. Maybe you should double check your ignition timing?
Hope this helps.
Old 03-28-2007, 09:26 PM   #4
doc1
doc1's Avatar
thnx for the help the only problem is that there are 2 plugs that look like the ingector plugs and i thnk i might have gotin them mixd up
Old 03-30-2007, 04:43 AM   #5
doc1
doc1's Avatar
thnx for the help, i ended up replaceing the cyl. cover gasket and i was down by my injectors and i noticeed one wasnt pluged all the way in and it had been like that sence i have put it back together in dec. but ne ways runs like a charm and purs like a kitten thanks for clrin that up for me
Old 03-30-2007, 04:08 PM   #6
IHateHacks
IHateHacks's Avatar
No problem, anytime.
Glad you got it running!
Fuel issues!! teedoff00 MKIII Supra 1 01-01-2008 05:09 AM
Fuel Octane scruffboy Non-Generation Specific Questions 3 09-08-2006 06:49 PM
