Old 01-25-2007, 04:48 AM   #1
Poptart
Poptart's Avatar
Poptart is on a distinguished road
Default 1jz!!
Hey, I have a 1990 Toyota Supra (Automatic)
I was wondering a quick question, with a 1 JZ engine...
Is it a direct drop in? Or what do you have to change out...from where I hear...it would just go right in...and you hook everything up...
So so...new ECU and all that...
I found a deal...sounds good, engine is clean, 800 dollars .. 1JZ Twin Turbo, 30-40k miles...Comes with ECU...Tranny (Auto) and all that good stuff...
CUT HARNESS...can I use my OLD HARNESS? Or do I need to upgrade? I don't know for sure..please let me know...
That is all the questions I have for now, if somebody could please take the time to answer them...
Thanks,
Ken
1990 Toyota Supra (Automatic) Non-Turbo Stock..
Dropping 1JZ-GE Twin Turbo --- 300 HP..goal is 500hp..
Got any parts? I buy them!
Poptart is offline   Reply With Quote
Old 01-25-2007, 05:55 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
you need the 1jz wiring harness as it is a
1jz
and you have a
7m
and they are two different engines
source a wiring harness and it will be plug n go
don't forget to get the alloy engine mount brackets for the engine also as they differ between the two engines
Pics of my build.
Do a diagnostic first!
Old 01-25-2007, 08:54 PM   #3
Poptart
Poptart's Avatar
Ebay has no wiring harness .. meh...
Where else can I get them with the mounting brackets?
Old 01-25-2007, 09:10 PM   #4
suprra_girl
7M POWAH! ;)
k... in theory
the 90+ 7mgte ecu will have the same type of plugs as a 1jz ecu does
cut them from a 90+ 7m harness and rewire onto your 1jz harness as it will need extending if you are lhd anyway. check out www.1jz-gte.us for ecu pin info.
when you go to buy the engine just ask them if it has the engine mount brackets. if not i guess you'll have to post in wanted forums and search ebay etc
Pics of my build.
