Old 12-27-2006, 04:24 PM   #1
scruffboy
scruffboy's Avatar
Default Gurrgling Coolant
When you first start a Supra MK III, should you here a gurgling sound in the dash (I assume heater), or is this a sign of problems? Any help would be appreciated.
Thanks,
Scruffboy
Old 12-27-2006, 08:57 PM   #2
Murd
Pretty common problem. It CAN be a BHG but more than likely you just need to burp your cooling system. Here's a link from Suprra Girl
http://www.toyota-supra.info/forums/...ead.php?t=3029
Also mrnickleye suggested once, and I can't remember where I just know it was him, to cut the dangley thing on your thermostat and bore the hole out to 4mm to help reduce this problem in the future.
Old 12-28-2006, 12:44 AM   #3
scruffboy
scruffboy's Avatar
Default Gurgling
Thanks Murd,
I'm pretty sure no BHG but I'll chek on how to burp it, thanks.
Scruff
Old 12-28-2006, 03:11 AM   #4
Murd
Just glad I know enough to be able to help the community back
Old 12-28-2006, 03:35 AM   #5
Monkey
Monkey is on a distinguished road
For anyone who needs to bleed air out of their coolant system, the easiest thing to do is to get a coolant fill funnel kit. It is pretty inexpensive, and you don't have to go through the same process that Suprra girl went through. This is a one shot deal. Anyone want to know how to do it, shoot me a pm. I'll be happy to explain.
Monkey is offline   Reply With Quote
Old 12-28-2006, 12:31 PM   #6
scruffboy
scruffboy's Avatar
Default Wait a minute
At the SupraGirl site I read this quote "***note... water WILL pass thru heater core when thermostat is closed, (on a cold engine)****". So is what's happening normal on cold start? After the engine warms up all sounds disapear. This has just started to happen as the temperature here dipped a little in the mornings (I get up real early).
Scruff
Old 12-28-2006, 02:41 PM   #7
Cool
the gurgle noise is caused by a small lack of water . either you leaked water or pushed it out at some point just enough for a small amount or air to be in the system when the engine heats up the coolant system expands and the air pocket is gone and so is the gurgle . you need to keep a very close eye on where the water is going . the coolant system should not use lose or use water ever.
check the radiator level and the reserve water bottle level every morning . if you keep adding a little water here and there you need to dig for a leak, if there is not a leak
you are on your way to a BHG . i've had 3 supras and dealt with 4 bhg's .
you better hope the gurgle is a one time oops the system was low thing . a supra will fool you into thinking it's not a BHG
Old 12-28-2006, 07:01 PM   #8
scruffboy
scruffboy's Avatar
Default Hey DDMCSE
Now ya have me scared. I also recently had a new water pump installed. Could this have caused air to get in the system?
Scruff
Old 12-30-2006, 02:45 AM   #9
Monkey
Scruff
Yep, because when you pull the water pump off, the coolant leaks out of the block, letting air in.
Old 12-31-2006, 01:49 PM   #10
Cool
ofcourse that would cause the water fall gurgle
top it off and watch it .
Funky engine coolant issue shirkinator Non-Generation Specific Questions 1 06-22-2009 08:37 AM
coolant on top of piston sevenmgte MKIII Supra 8 05-02-2008 02:34 AM
