Old 12-25-2006, 01:12 AM   #1
Supra2NR
Supra2NR's Avatar
Default amp wiring
ok i am stumped
i have installed
single amp, dual subs
dual amps, triple subs,
triple amps, triple subs
triple amp, dual subs, interior speaker combinations b4
now i am trying to install
this is the most simplest setup i have ever did
a single 12 single amp setup in my mk3
but the fuse keeps blowing out
i have a sony xplod 1000 watt 2 channel amp
with a 12 inch xplod sub
i got an inline fuse (30A)
the two fuses in the amp are 30A too
everytime i put the fuse in it blows
ive tried:
taking the power wire from the battery, put the fuse, when i put it the power back in it blows
took the ground wire from the battery, put the fuse, when i put it back it blows
tried the same thing with the power wire from the amp, same thing happnd
tried the same thing with the ground wire from the amp, same thing
i have went thru a whole pack of fuses already i am stumped and frustrated
any help will be appreciated
Old 12-25-2006, 08:11 PM   #2
Supra2NR
Supra2NR's Avatar
Default I had a dream
Nevrmind the prior question
Last night I had a dream and my subconcious mind talkd to me and told me
Your wires are inverted, idiot,
Switch the power and the ground dumbass!!
And sure enuff I woke up this morning
The wires wasn't in the right place in the amp, that's why it kept blowing the fuse
But I have another question
Everytime I crank the volume up and start get sum bass, the amp shuts off as a safety feature, what could be causing this?
Old 12-26-2006, 02:44 AM   #3
j3pz
maybe its getting too hot? i dunno my knowledge of amps is limited
Old 12-26-2006, 02:56 AM   #4
Supra2NR
Supra2NR's Avatar
thanx for the info,
but i got it fixed,
to anybody getting amps
dont get sony xplods, they suck
i tried bridging the amp and its jus keeps shutting down on me
so now i only can use a single channel and half of the amps power
Old 12-26-2006, 05:36 AM   #5
damdog05
damdog05's Avatar
oh yeah...you could have asked and someone would have told you not to go for xplod. im a rockford fosgate guy myself but there are many other options besides the xplods. if you wanna look for a different setup check out the audio section of the forum, people have posted all about what the run in their cars.
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
Old 12-26-2006, 03:56 PM   #6
Supra2NR
Supra2NR's Avatar
it was a christmas present,
i usually go for diamonds or mtx
but what can i do , theyre working right now so yea
Old 12-26-2006, 09:03 PM   #7
burton51m
burton51m's Avatar
Originally Posted by damdog05
you could have asked and someone would have told you not to go for xplod. im a rockford fosgate guy myself.
+1
Old 12-26-2006, 10:04 PM   #8
Jeff_5_7
Jeff_5_7's Avatar
Jeff_5_7 is on a distinguished road
i have the same amp and have problems with it somtimes but i got my brothere ot fix the m the one problem i have is that i have 2 infinty 12s on my sony 1000 watt amp and i have ot run both subs o none channel when i try to put one sub on each channel only one of them works the map wont let me run one speaker on each channel i no it not because the channel is blown becaseu can put them both on the other channel and they work
Jeff_5_7 is offline   Reply With Quote
87 Supra Wiring Harness slader99 MKIII Supra 9 04-28-2008 12:14 AM
question about wiring harness????? tone loc MKIII Supra 2 08-30-2006 09:20 PM
HKS VPC wiring diagrams cat007 MKIII Supra 0 11-07-2005 09:28 AM
