Old 11-26-2006, 06:38 PM   #1
Rob420
Rob420 is on a distinguished road
Default Internal motor Question?
My 87 7m-ge had a slight rod knock when I got it. It did not necesarily get worse just bugged me worse. So (being poor)lol I went the cheap route and lifted the motor and changed each rod bearing one at a time. After each one manually spinning the motor to feal for binds. Found one bearing that had been really hot and some pits. I have put 300 miles on the car since the bearing job and that seams great! But now I hear a rocker arm I think so my question is, Being DOHC can you check and set valve lash just by removing the covers?Oh and the top end of the motor was supposably done a year ago but have found that mechanic fairly incompitant.
Rob420 is offline   Reply With Quote
Old 11-26-2006, 06:57 PM   #2
Unhappy tough job
Not an "easy" job, especially the first time, and more so for a 'non-mechanic'.
http://www.cygnusx1.net/Supra/Librar...tion=EM&Page=7
Old 11-26-2006, 07:23 PM   #3
Rob420
Default Some mechanical ex
But most all with small block Chevy. So the over head cams just add a new challenge. Thanks for the help
7mgte -- Internal Specs Wolfpac251 MKIII Supra 3 07-03-2006 09:06 PM
