Old 11-25-2006, 12:31 AM   #1
lsgheero
lsgheero is on a distinguished road
Default big problem!!!
okay i fixed my starter issue but i went to change the sparkplugs and there is oil/gasoline in the place where the spark plugs go!!! any ideas what would cause this so far i have had people tell me its a BHG and that its bad seals, and rings.
Any takers as to what the prob might be and also if what they said is the case then should i just try for a engine swap?
-larry
lsgheero is offline   Reply With Quote
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
found the problem brs86supra MKIII Supra 0 05-02-2006 03:42 PM
Boost Problem, I Guess nonstop213 MKIII Supra 0 02-23-2006 07:32 PM
tsp problem for na t supra jdlee123 MKIV Supra 0 09-02-2005 06:01 PM
