Old 11-22-2006, 10:12 PM   #1
SupraDupra
SupraDupra's Avatar
Default Power steering belt jumping off
Drove my supra to work today and when I got into the parking lot I dumped the clutch and laid a patch accross the lot ,and my power stearing belt liberated itself from the pulley.I put it back on and proceded to try and turn out a doughnut ,this time I broke the belt.This is a brand new belt and there is more than enough tension on it - has anyone else had this problem? Are there pulleys with deeper grooves available? On my second attempt I wound up pointing at a company truck without the power stearing and my PCV filter popped off and stuck the throttle up (Clutch in ,shut down ).So I need to address this issue.
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
Old 11-22-2006, 11:15 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
I've had this happen twice, I thought it might have been the small amounts of axis play in the pulley shaft (it moves in and out slightly). Fitted a new belt and the same thing happened again. The only thing I can think of is when you tighten the securing nut the pump moves towards the engine slightly which reduces the tension on the belt. The next time I used a bar between the engine and pump to hold it in position whist I tightened the nut. I also tightened the nut that the pump pivots on from under the car,which I left loose the first time. If it had an adjusting bracket like the Alternator it would make things a lot easer. So far I've done 20 k miles without a problem.
power steering pump daluxsrt4 MKIII Supra 1 08-29-2008 02:17 PM
Power Steering Pump and Fluid Chambers MKIII Supra 8 06-29-2008 03:59 PM
Power steering pump.. 89 turbo. 2JZEFINI-17 MKIII Supra 4 03-13-2007 03:23 AM
Power steering fault david small Non-Generation Specific Questions 1 09-20-2006 12:41 AM
