Old 11-07-2006, 03:04 AM   #1
toalan
toalan is on a distinguished road
Default Karman Frequency Vs Air Flow?
Hi guys,
I need to know the karman frequency vs airflow for toyotas or for any car. I have searched the net and came up with nothing. At the very least I need to find out what is the ballpark Max frequency you can expect in real life from a KV airflow sensor.
I looked at the "MAP ECU" manual and it says that the KV frequency ranges from 16hz to 3000 hz. Another site suggests that the max is 160hz. I have a hard time believing that the KV sensor can output a 3000hz signal because that would imply that the mechanics inside the sensor moves @ 3000 hz. 3000 hz is pretty fast for anything mechinical.
Any info or links you guys can provide would be appreciated.
Regards,
Alan To
toalan is offline   Reply With Quote
My Air Flow Sensor SuperSpartan Non-Generation Specific Questions 0 05-01-2008 08:45 PM
Mass Air Flow FullOfProblemsMKIII MKIII Supra 1 02-12-2006 08:50 PM
air flow meter conversion mrmoo Non-Generation Specific Questions 0 07-02-2005 11:38 PM
