Old 09-16-2006, 06:30 PM   #1
sportriderseattle
sportriderseattle's Avatar
sportriderseattle is on a distinguished road
Question MKIV OEM 17" wheels chrome or polished?
I'm hoping that an MKIV expert can clarify if the '96 to '98 Twin Turbo OEM 17" wheels were either chrome plated or simply polished from the manufacture? If they were just polished do you know if they put a clear coating over the top to prevent oxidation? Thanks in advance for your help.
Dan
http://www.cardomain.com/ride/2200872
1987 Toyota Supra Turbo Targa, 5 speed, Light blue, 67K miles, MKIV TT polished wheels
sportriderseattle is offline   Reply With Quote
Old 09-16-2006, 11:01 PM   #2
Supra2NR
Supra2NR's Avatar
i dunt think polish aluminum wheel rust. dont think so
but check up on that sum more
Old 09-17-2006, 11:32 PM   #3
sportriderseattle
I think you missed the question. It's not about rusting; I'm simply wondering if the wheels are POLISHED or CHROME PLATED. They are both two different finishes. Thank you.
Dan
Old 09-18-2006, 04:13 AM   #4
Supra2NR
Supra2NR's Avatar
read the post bro,
he was asking if he needs to put clearcoating, if the rims are jus aluminum polished to avoid oxidation
oxidation is a the process when oxygen molecules starts bonding with another element
when oxidation occurs with metals, rusting occurs
i can try to do the science with this, if aluminum bonds with oxygen
but jus ask sumbody that knows if aluminum rusts
but most likely no, thats jus my opinion tho
Old 09-18-2006, 07:57 AM   #5
Murd
Aluminum doesn't rust the same way steel does. You do get oxide growth on it, and discoloration, but it really doesn't eat away at the aluminum. As for the wheels, I wish I could answer it for you, I would ASSUME they had a clear coat on em if they weren't painted, but I don't know for sure.
Old 09-18-2006, 08:09 AM   #6
Supra2NR
Supra2NR's Avatar
nah , most aluminum wheels, when they say polished, they mean it lol
but you'll be good tho, like he ^ said, it wont rust
Old 09-18-2006, 02:42 PM   #7
Murd
Depends on the brand, Alot of aftermarkets aren't polished, but some are. A friend of mine has a 924 with fittipaldies that are aluminum with clearcoat. Some of the clearcoat chipped off and it's starting to oxidize in those spots, but the rest of the wheels look good. Being stock wheels my guess is toyota went the extra distance and coated em, but again, I'm not 100% sure as I don't own a MKIV
