Old 08-21-2006, 05:24 PM   #1
SupraSaver87
SupraSaver87's Avatar
SupraSaver87 is on a distinguished road
Smile Home Fabrications
This question goes out to all who CAN reply.
What "Home fabricated" things can I all make for my 88 T? I am looking to up the power for cheap, until I can buy some things. Looking for a fabricated cold air intake...if its possible. I have access to a madril Bender, and welder, as well as having a very mechanical mind...so I can figure out most things suggested.
Post ANYTHING here, maybe this topic can turn into an idea swapping section as well!
My Ride: http://www.cardomain.com/ride/2351563
Our Supra’s, which art in the driveway,
Hollowed be thy power, thy mods are great, thy speed endless,
On the road or at the track. Give us this day free of cops,
And forgive us our impound charges, as we forgive those who are slow.
And lead us not into speed traps, and deliver us from the interceptors,
For thine is our car, the power, and the glory…forever and ever….amen.
SupraSaver87 is offline   Reply With Quote
Old 08-21-2006, 05:39 PM   #2
ddmcse
ddmcse's Avatar
Cool
make yourself a downpipe to replace the stock one and keep going to the end of the car with 4 inch pipe
this will loose the pre-cats in the downpipe and remove the cat from the exhaust
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 08-21-2006, 06:47 PM   #3
Supra2NR
Supra2NR's Avatar
did sumbody say homemade??
you came to the right place
and u can ask weezl too with this
but here's one
homemade cold air intake
all plastic tubes with rubber connectors
and painted to look good
afm was moved and painted too
to match the rest of the intake
but since you got access to mandrel bender
making it out mof metal shouldnt be too hard for you
here's another one
homemade, windsplitter or front spoilers
like sum pple call it
the original was made out of wood
but a fiberglass version is on its way
also painted to match the car
here's another one thats easy to do
this one you actually got sum options
use paint stripper with the rims and end up with this
or you can do sum more with it
make it more yours
and come up with this
and this one is probly the best
homemade upgrade that you can do with your car
a short shifter upgrade
all you need is one of a momo type
shift knob
that has screws on the side
cuz you wont have the thread the when you do the upgrade
a little paint and the shift boot looks beautiful
Old 08-21-2006, 09:21 PM   #4
burton51m
burton51m's Avatar
my air duct has to be my favorite upgrade...
nuthing like getting fresh cold air into the engine.....
edit- its made for dryer's and can be found at home depot but you can probably find something around your house to make this
Old 08-21-2006, 09:28 PM   #5
SupraSaver87
Default Keep in mind...
I have a turbo, so I have an intercooler....the last one looks like it's on a N/A...correct me if I am wrong.
Old 08-22-2006, 06:22 AM   #6
Supra2NR
Supra2NR's Avatar
do you have access to a welding machine?
cuz you can make a custom intake pipe with the
blow-off valve on the pipe,
you can still do the airduct upgrade
i recommend doing that
with a filter with a funnel on the top
so that way
fresh air will be directed into the filter
like at the tip of my filter
do u have an auto or manual?
u can do the short-shifter upgrade
you can do the rims too
wasnt really that hard too
Home made smoke screen sprigmo1 MKIII Supra 4 11-19-2006 08:46 PM
Supra is home! Murd MKIII Supra 27 11-15-2006 11:53 PM
Timing Belt Change, Do It at Home mrnickleye Supra FAQ 2 09-19-2006 06:24 AM
