Old 07-14-2006, 10:31 PM   #1
vancouver874
vancouver874 is on a distinguished road
Default Cooling system problem
You will soon tell that I know little about cars. My son's 87 Supra turbo has a coolant hose running from the rear of the engine (nearest driver) to a plastic contraption mounted on the firewall. The inlet tube on this plastic piece has broken off. Can someone tell me what this plastic thing is called and is it hard to replace if we can find a replacement part
vancouver874 is offline   Reply With Quote
Old 07-16-2006, 07:20 PM   #2
ddmcse
ddmcse's Avatar
Cool
it's a heater vsv switch
it's a vacuum controlled valve that allows coolant to flow into the cabin and the heater core
http://www.ddmcse.com/turbo/heatervs.htm
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 07-17-2006, 03:43 PM   #3
vancouver874
Thanks for the info - much appreciated
Cooling system Oddity skatecboy45 MKIII Supra 4 07-30-2008 09:38 PM
This is kind of Weird, Problem with Electric System woundsofchrist Non-Generation Specific Questions 0 11-04-2007 06:53 PM
high pressure in cooling system jarekt Non-Generation Specific Questions 3 09-01-2007 06:39 PM
burping the cooling system from air bubbles suprra_girl MKIII FAQ 2 04-19-2007 05:40 AM
Cooling system question thunder550 MKII Supra 8 12-17-2006 12:53 PM
