Old 06-27-2006, 07:52 PM   #1
88 MARK3
88 MARK3 is on a distinguished road
Unhappy Waterfall sound on cold start! HELP!
There is a waterfall sound on cold start on my supra...what problems are there???
I got that sound but don't know what the problem is....engine runs good...temperature is good....
anyone have any idea of what the problem may be?
(It is a Turbo model if it halps!)
Also my supra has 189000kms on it right now.
Anyone have any idea where I can start to look for any problems of the car?
I did smell some burning smell a couple weeks ago while driving but only for a couple minate. Any idea of what may have cost the burning smell???
88 MARK3 is offline   Reply With Quote
Old 06-27-2006, 11:41 PM   #2
Do a search for waterfall, this has been thoroughly talked about.
Old 06-27-2006, 11:53 PM   #3
dcrusupra
dcrusupra's Avatar
. Im very sorry to hear this news. As it sounds like a BHG. Drive the car around for a half hour or maybe less and you will see the temp go up.
New Rebuild
My CarDomain
Old 06-28-2006, 01:44 AM   #4
Cool
top off the coolant and check closely for leaks over the next few days .
i hope you find a leak
the water fall sound is caused by a lack of coolant
Old 06-28-2006, 03:28 PM   #5
88 MARK3
The Temperature is find even if I drive it for more then half an hour.
Coolant topped off. There is a tiny leak in one of the little tubings up front though. But it is a minor leak.
Old 06-28-2006, 03:46 PM   #6
IHateHacks
IHateHacks's Avatar
I'd pressure test the cooling system. Should hold 17 psi and not drop. They are like $50.
Old 06-29-2006, 04:44 AM   #7
What are $50 ??? the test?? Most 'honest' (and not greedy) shops would put the pressure tester on for free. Takes a few minutes.
Old 06-29-2006, 03:45 PM   #8
IHateHacks
IHateHacks's Avatar
Yeah for the tester. I meant go to the store and buy the tester and test it yourself and have the tester forever instead of driving to some idiot shop and letting some dummy do it.
Cold Start problem mkiiisupra MKIII Supra 1 02-22-2008 05:38 AM
Cold Start System atsomepoint Non-Generation Specific Questions 1 08-16-2007 03:31 PM
my car only start when cold? supfoo514 MKIII Supra 3 06-04-2006 11:22 PM
Cold Start problem bigal0043 MKIII Supra 4 10-12-2005 02:40 PM
