Old 04-23-2010, 06:51 AM   #11
littlegirl
littlegirl is on a distinguished road
I was going to say getting rid of the old gas can be a major helper!
littlegirl is offline   Reply With Quote
Old 05-12-2010, 11:20 PM   #12
batmmannn
batmmannn's Avatar
Default Just started mine after 6 or 8 years
Mine sat because of a bad starter and because I had another Supra. Other Supra developed a head noise so finally I laid in the driveway in leaves and sticks and busted knuckes getting the starter changed from below. Penetrating oil in the jugs overnight in 4 of the 6 cylinders, cranked it pushing oil out the next day, put the old plugs back in and added 2 gallons fresh fuel and it's alive showing a third of a tank of basically paint thinner at this point and its kicking topped off coolant with water for now till I do a flush. Critters had built a nest in left side of exhaust blowing out the muffler so I will need a muffler. Tires were still good but who knows for how long, a relief cause tires cost money for this car.
Scared the shit out of me because it started blowing steam out of the exhaust on a round the block trip, happened as I was going up a large hill. Has cleared out now so I am guessing it had some water in the exhaust. Runs like a car on 8 year old gas and old plugs looking forward to fresh gas and a nice run down these WV windy roads.
Check out my video;
http://www.youtube.com/watch?v=Qvulf_cNK_Q
Edited today.
You might want to replace your timing belt as well. I think I broke mine today.
Old 05-31-2010, 07:20 PM   #13
ricer
ricer is on a distinguished road
on your 86and a half what ended up being the proble with the tapping, i just baught a 87 trubo and it is makeing a simalar noise and i dont want a shop to charge me up the wazoo for a simple fix
ricer is offline   Reply With Quote
Old 05-31-2010, 08:47 PM   #14
batmmannn
batmmannn's Avatar
Default Tapping
Not sure yet, it could be a timing issue or it could be a broken valve spring. Not sure. I have it to some degree on both my cars. One fella told me he put a washer in between the distributor tightening adjustment bolt and the head to make the distributer pull slightly away from his head and this took it away from his. Others have mentioned it could be arcing plug wires or spark knock from incorrect timing. I have been working on the Red Supra. my Black 87 is the one with the loud noise. Once I finish getting the Red one road worthy I will try to find time to work on my black one. Doing the exhaust and tires now.
Old 06-01-2010, 02:42 AM   #15
ricer
thanks, that sorta helps, the guy who rebuilt the motor torld me he thinks its a rocker, but with all the things up with it right now theres no telling, and i am in the same with the tail pipe stuff mine is only half way back off the turbo so i have to get a custom one made, and i got a oil leek from somthing to, the life of a supra owner is not a cheap one i guess
Old 06-01-2010, 03:31 AM   #16
batmmannn
batmmannn's Avatar
Default Stop right there
OK BIG RED FLAG! If the guy that told you he rebuilt this motor said he thinks the noise is a rocker you have a big problem. This motor does not use rockers nor does it have any. The cams ride on top of the valves. There are no rockers!!!! This guy is feeding you a line of crud.
Old 09-12-2010, 11:49 PM   #17
supragreen
supragreen is on a distinguished road
Default 82 supra
I HAVE A 82 SUPRA THAT SAT FOR 7 YEARS WITH A FULL TANK OF GAS NOW I HAVE TO FIX THE TANK NEW LINES PUMP AND FILTER I HOPE NOT THE FUEL EJECTOR
any advice lol
supragreen is offline   Reply With Quote
Old 09-13-2010, 03:00 AM   #18
batmmannn
batmmannn's Avatar
Default Air filter
Check air filter and make sure no critters got in there.
Old 01-27-2014, 04:37 PM   #19
DaveC
DaveC is on a distinguished road
Default Turned the key..wipers activate, no starter response.?
I bought a 1986 P type sight unseen and I think I am screwed. Does the Supra activate it's wipers with the start cycle?
DaveC is offline   Reply With Quote
Old 02-01-2014, 03:09 PM   #20
Dirty
Dirty is on a distinguished road
Default My supra won't start
My supra has been sitting for 4months and now all it does when I try to start it is taps very loud any ideas?
Dirty is offline   Reply With Quote
