Old 03-09-2005, 10:17 PM   #1
88supraTony
88supraTony is on a distinguished road
the little yellow box on my 88 supra wont work and the dealer want $142 , where can i find one online cheap. i have looked around in junk yards and can't find one.
Also, where exactly is my fuel filter located? :blink:
88supraTony is offline   Reply With Quote
Old 03-11-2005, 10:45 AM   #2
das
das is on a distinguished road
sorry i dont know where a replacement can be found, is it your brake lights not working or just your rear lights as when my box failed my brake lights still worked fine, it just knocked out my rear lights and there is a free way around that
das is offline   Reply With Quote
Old 03-11-2005, 03:40 PM   #3
88supraTony
my tail lights work fine when i turn on the parking/headlights, i have no brake lights whatsoever
Old 03-12-2005, 01:25 AM   #4
300hpvision
300hpvision is on a distinguished road
what year is it
HELP ME FIND A STOCK SUPRA DAMN IT!!!
300hpvision is offline   Reply With Quote
Old 03-12-2005, 04:47 AM   #5
88supraTony
1988 7mge
Old 03-12-2005, 08:38 PM   #6
88boostr
88boostr is on a distinguished road
the same thing just hapened to me. i went to the junkyard a found a box for 12 dollers. good price
88boostr is offline   Reply With Quote
Old 03-13-2005, 04:40 AM   #7
Supra Guestobrut89
Guest
Posts: n/a
i had the same prob its a little button that turn them on when you press the pedal its stupid how it works when you press the pedal it releases the button when you let off the pedal it pushes back in its located in the back of the pedal
Old 03-14-2005, 07:24 AM   #8
^ i would agree.... the switch located on the brake pedal may not be making contact with the pedal hence the lights not working
do you have a light on your dash saying you have brake lights out, if you don't then i would say it is the brake pedal switch that needs adjusting
Old 03-16-2005, 06:32 AM   #9
targattgirl
targattgirl is on a distinguished road
yeah make sure the brake switch at the pedal is operating correctly.
I had to fix some cars with the same problem. there's supposed to be a rubber groomet thing that pushes the brake switch when you push on the pedal. sometimes the rubber piece falls off, so make sure when you push the pedal, you are pressing the swich all the way down too.
did you check the basic stuff like your bulbs? check if you are getting power to the bulbs? check the fuse?
targattgirl is offline   Reply With Quote
Old 03-16-2005, 08:27 AM   #10
with mk3 supras the brake pedal works opposite to what the cars you have worked on previously....
when the pedal is released it pushes the switch which turns off the lights, when pressed the switch is released and brake lights turn on
sounds like you got some good info to offer here targa girl.. welcome
Brake Lights zebrahabitz MKIII Supra 2 08-13-2009 06:29 AM
Dash lights Don't Work!! supra67 MKIII Supra 0 08-10-2006 01:11 AM
87 supra brake lights ministrytrav MKIII Supra 4 11-23-2005 08:53 PM
