Old 06-06-2006, 03:57 AM   #1
shaggymx3
shaggymx3 is on a distinguished road
Exclamation 86.5 7mgte
I am having a boost problem. The car is bogging down while under 3psi. This is my First Turbo supra and im not understanding why it does this.. i do have a major exhaust leak by the second cat, and i might have one on the down pipe. Will this effect boost? when ever it spools it bogs down, my knock sensor code is up and also turbo pressure sigal?? what do i do to fix this problem
shaggymx3 is offline   Reply With Quote
Old 06-06-2006, 09:36 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
the turbo pressure signal = you have a boost leak which is causing the bog
also you will more than likely find that the wire has broken off the knock sensor plug or has a short circuit, or is not plugged in at all
there are two knock sensors on the intake side of the block about #2 cyl & #5 cyl
pull the plugs off and inspect them
good luck
Pics of my build.
Do a diagnostic first!
7mgte install in na 86.5 supraman121 MKIII Supra 1 01-13-2007 03:04 AM
7mgte and 7mge question supraman121 MKIII Supra 2 01-12-2007 09:09 PM
making a 7mgte huggybear16 MKIII Supra 2 09-02-2006 09:14 PM
