Old 05-25-2006, 11:15 PM   #1
88 MARK3
88 MARK3 is on a distinguished road
Default TEMS Problem!
I am new to this. Just got myself a 88 turbo. But I have a Problem with my TEMS system.
I was wondering if anyone can help.
The problem is when I step on the brakes, the TEMS kicks in and works fine.
But when I am at high speed and when I hard accelerate, the TEMS doesn't seem to respond (Doesn't kick in at all).
Any one know what is going on and how I can fix this problem?
Do I need to replace the stock suspensions?
I don't think there is any fuse or relay for the TEMS. If there is, I can't find it.
I have a repair manual but it doesn't say anything about it.
If anyone can help...it would be much appreciated! Thank you!
88 MARK3 is offline   Reply With Quote
Old 05-25-2006, 11:55 PM   #2
burton51m
burton51m's Avatar
Post
I have TEMS also...i do not feel the tems kick in really at all. but when i brake i can see the little 3 lights come on so they must be working eh?
what i am trying to say is that i cant feel mine kick in at high speeds or accl. ether.
How would you tell?
Old 05-26-2006, 12:23 AM   #3
Supra2NR
Supra2NR's Avatar
eveb when u change it from normal to sport u can barely feel it , sometimes if its queit enough u can hear it , but when u brake or turn hard (i dont advice looking at it while turning hard) but when the three lights come on its working,
the tems barely does anything tho, jus some dampening on the shocks to handle diffrent types of road surface
but when your on the e-way i think when your doing 70 mph it changes to sport automatically
Old 05-26-2006, 04:05 PM   #4
88 MARK3
Also... when I am driving and I hit a bump or something, it tense to bounce around alot. Is the strut dead? Coil spring? CV joint? Upper/lower arm? stablizer bar? or the whole suspenion?
If I get it replaced, would it be better to just put custom ones on it? or do I have to stick with the stock? I heard that the stock TEMS suspension is overly expensive and doesn't do much to help with handling etc...
Old 05-26-2006, 06:28 PM   #5
damdog05
damdog05's Avatar
so i have the same problem with my suspension, i bounce around a lot when i go over bumps and such. anyway...i was reading in a repair manual i have that when the TEMS lights come on it means there is a problem with the TEMS. now you might wanna check that out with someone more knowledgable about supras than me but itll give you somewhere to start.
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
Old 05-27-2006, 02:51 AM   #6
burton51m
burton51m's Avatar
after you go over a bump/hump and your car keeps on bouncing up and down that means youre struts are bad
Old 05-27-2006, 06:01 AM   #7
Wink Check the FAQs
Read the thread on TEMS in the FAQs section. Then you may have some more questions.
Old 05-27-2006, 04:30 PM   #8
damdog05
damdog05's Avatar
ok so i read the FAQ, please disregard what i said about the lights signaling a problem. i love this forum. i learn so much from everybody here.
My cars:
Old 05-29-2006, 03:18 PM   #9
88 MARK3
Yeah...I figured it was the shocks. Would I be able to go for customs shocks or do I have to stick with the TEMS ones? Is customs shocks better? Please advise.
Old 05-30-2006, 02:17 AM   #10
Supra2NR
Supra2NR's Avatar
of course custom shocks, they'll give u the drop that stock suspension cant offer , and give you better handling
i suggest looking at the tein flexes with the EDFC
