View Poll Results: b4 voting read my post about the beating
Did i act over the edge by whoopin his @$$ 2 100.00%
Did he Deserve what he got 0 0%
Voters: 2. You may not vote on this poll
Old 05-23-2006, 02:48 AM   #1
Supra2NR
Supra2NR's Avatar
Default car wont start
what the hell, ok b4 everybody gets on my case its not the afm cuz it ran after i fixed the intake and i dusted a prelude last saturday ok,,, so its working properly,, now the car cranks but wont turnover what the hell is wrong wit it,
anybody got any suggestions pls reply asap,
everytime i get sumthin good goin sumthin is jus bound to go wrong
Old 05-23-2006, 03:14 AM   #2
wiggle the wires on the cps?
Old 05-23-2006, 03:35 AM   #3
Supra2NR
Supra2NR's Avatar
cps?? sori new to this engine what do ya mean?
Old 05-23-2006, 08:37 AM   #4
cam position sensor... green or grey 4 wire plug, wiggle wires then try starting
Old 05-23-2006, 10:35 AM   #5
right front of the engine , right next to the power steering reservoir
round object that plugs into the head .
mine does the same crap once in a while I haven't figured it out exactly yet.
but i wiggle the cps wires and unplug then replug the afm harness ,
if that doesn't work i pull plug #1 , sniff for gas then put it back in , if that doesn't get it i disconnect the battery for a few minutes ,
Old 05-23-2006, 03:07 PM   #6
Supra2NR
Supra2NR's Avatar
still does the same thing,
wiggled the cps already
disconected the afm
and put it back
took off the battery too
dont know what the hell is goin on
or maybe i did sumthing wrong
its this thing here right?
nother thing how do u put pics in the signiture?
Old 05-23-2006, 09:56 PM   #7
theWeezL
theWeezL's Avatar
Supra2NR...why am I not suprised...
what did you do before it stopped working? or was it running fine last night...and suddenly this morning wont start kinda thing?
I hate to state the obvious, but is it out of gas?
Check to make sure nothing is disconnected that wasnt already disconnected last time it was working...(coil wire, etc.)
also there is a main circuit breaker for the car and at least 2 fuses that will keep it from starting...check those
if all that looks ok...take the number 1 spark plug out, and while holding the threads against a solid ground (I recommend using rubber handled plyers for this) have someone crank the engine...do you get spark at the plug and is it blueish or white/yellow/orangeish? If no spark you want to start with things like distributor, coil, ignition, etc.
If you got spark then the next thing to check is for Fuel pressure...there is a bleeder valve on the fuel rail (kinda like a tire valve) press it down a little and see if fuel squirts out...if it doesnt then you need to check things like Fuel pump, filter, fuel regulator, etc...
Good luck
Old 05-24-2006, 06:53 PM   #8
Supra2NR
Supra2NR's Avatar
why u gotta break balls? i know i know ur not suprised, but like i said i checkd everything that they said b4 now its ur suggestions that im gonna look into ill holla back when sumthin goes right
by the way mind telling me where the circuit breakers r? and which fuses i need to look at
Old 05-24-2006, 07:39 PM   #9
theWeezL
theWeezL's Avatar
ECU fuse - 15A: http://www.cygnusx1.net/supra/librar...be/BE_010.html
drivers kick panel fuse block diagram: http://www.cygnusx1.net/supra/librar...be/BE_013.html
underhood block diagram: http://www.cygnusx1.net/supra/librar...be/BE_014.html
how to reset a circuit breaker: http://www.cygnusx1.net/supra/librar...be/BE_004.html
Old 05-24-2006, 07:52 PM   #10
Supra2NR
Supra2NR's Avatar
Angry
how the hell does oil flood my sparkplugs ,
any takers for this one
i cant think straight cuz right now i feel like choking the guy that sold the car to me
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
