Old 05-15-2006, 11:58 PM   #1
Supra2NR
Supra2NR's Avatar
Default sumbody stop me
ok hurry up if im wrong sumbody stop me quick , cuz im thinkin about completely bypassing the afm , by literally opening up the trap door so air would pass thru without any restriction, or would this jus fuck me over?
Old 05-16-2006, 04:06 AM   #2
Talking Leave well enough Alone
Not to be Too rude, but its obvious you don't understand the principles of the Computerized Automotive System.
So......I will tell you like I tell others with that same lack of knowledge.....
"If you don't know what you're doing, Don't mess with it !! Cause you'll end up paying $$$$ heavily for it".
The parts are on the car for a reason. Every part serves a purpose.
In the case of the AFM (Air Flow METER) it measures the amount air coming into the engine. It does this using that little spring loaded door.
Google the net for some info on how this type of system works. There are millions of cars using it (Toyota, Nissan, Ford,etc).
Old 05-16-2006, 06:36 AM   #3
Supra2NR
Supra2NR's Avatar
i kno what its for , its jus pissin me off , cuz its sumthin that i cant take out, all that i can do is jus maybe take off some tension on the springs and thats it , but dunt worry no offense taken , i jus wish manufacturers would hav seen this and came up with sumthing,, u kno , kinda like the random technology catalytic converter,they are the first one to manufacture a 3 inch catalytic converter. its not a big revolution in racing, but its an advancement
Old 05-17-2006, 01:07 AM   #4
You can remove the AFM if you use a 'stand alone' air/ fuel management system.
Old 05-17-2006, 07:05 PM   #5
Supra2NR
Supra2NR's Avatar
ok thnax 4 that , were u the one that was wondering if u can move the afm close to the throtle body well im gonna try that tomoro, what i wanna know is the afm gonna work upside down bcoz the wire is not long enough for it to be right side up, now if it will, jus hit me up in here im gonna check here tomoro b4 i do it tomorow
Old 05-19-2006, 02:29 AM   #6
That's an interesting question. I don't know if it will work upside down. Thinking about it, and having had a couple completely apart, I'd say it will work.
how to stop belt squeak justin1642 MKIII Supra 5 08-25-2007 06:32 AM
"lock stop replacement"?? Japanese supra tt MKIII Supra 11 07-01-2007 02:35 AM
Idles low and dies at stop Chomper MKIV Supra 0 02-09-2007 05:19 AM
Next stop at South Florida… tork Off Topic Forum 5 07-10-2005 04:10 AM
Next stop Hershey PA. tork Exterior , Interior, and Detailing 1 05-20-2005 05:19 AM
