Old 05-07-2006, 09:12 AM   #1
Joseph
Joseph is on a distinguished road
Default 1989 Supra Turbo
Help
I am search for a parts car to repair my 1989 supra which has a badly damaged front end. Question. Are front end body parts from other years interchangable with my car? They look the same. If so, what is the range of years that front end body parts will be interchangable with my 1989. Example 87 88 90 91 all look alike to me, but I am not an expert...
Thanks joeC
Joseph is offline   Reply With Quote
Old 05-07-2006, 09:17 AM   #2
Joseph
Default Supra 1989 Parts
Are body parts from other years interchangable with a 1889 supra??.
Need a complete front end or parts car to repair my 1989. Will parts from a 87 88 90 91 fit my car?
Old 05-07-2006, 10:53 AM   #3
double posting is not necessary
yes parts from other years will fit your car
Old 05-19-2006, 05:15 PM   #4
Joseph
Default Compatible body parts
Need less vague answers . Does anyone have specifics relative to what year front ends are compatible with 89?For example wll 88 parts fit without problems or modifications. ?? Or perhaps 1990 ?? Thanks
Old 05-19-2006, 10:18 PM   #5
i'm not sure what part of
"yes they will fit" you're not getting
what parts do you want to swap over?
taillights, example you either need to drill two extra holes or remove those bits altogether to fit the lights
front bumper, has two extra boltholes required to bolt up the center part, but you can do without
Old 05-20-2006, 07:09 AM   #6
Supra2NR
Supra2NR's Avatar
i think this is what he wants to hear.
ok you hav a 89 MK3 so any other MK3 body should be fine
now i was jus told theres a slight diffrence between the corner lamps from 88 and lower cars because the corner lamps are a little bigger than the 89 up models, but the whole front bumper should be no problem since they all bolt on the same spots,
i have a 88 mkIII personally i like the bigger corner lamps better they give more looks to your car
New to forum...1989 Bright Red Targa Turbo Supra Virgin, Pics included. whowouldfigga Show n Tell 3 03-13-2008 07:47 PM
