Old 04-30-2006, 07:46 PM   #1
Supra2NR
Supra2NR's Avatar
Default dome light issues
what the hell i wrong wit it ,, bulbs r fine fuse is fine , the thing wont turn on when the door is open and when i switch it on , anybody has any ideas please help out thnx in advance
Old 05-02-2006, 05:47 AM   #2
Isphius
Isphius's Avatar
What year is it? I have an 86, it does the same thing. I havent been able to figure it out either. With a volt meter it reads 12 volts at the terminals, but it wont light the bulbs.
Old 05-02-2006, 06:11 AM   #3
KNYFE
KNYFE's Avatar
KNYFE is on a distinguished road
Might have an issue between the switch and the light itself.
http://www.cardomain.com/id/FastnLowI30
Supra, I30 and A8 are above...
KNYFE is offline   Reply With Quote
Old 05-02-2006, 07:21 PM   #4
tonystarks
tonystarks is on a distinguished road
Talking me too!
I have the same problem except it only works when the car is off. I noticed it when me and my girlfriend were sitting in it having a "smoke" and it didn't turn on. Then I turned the car off and it worked just fine. I just use my visor-mirror light
86.5 MK Trey
7MGE
K&N Filter Kit
cheap ass exhaust
turbo swap in a few months
tonystarks is offline   Reply With Quote
Old 05-03-2006, 04:12 PM   #5
Isphius
Isphius's Avatar
According to the volt meter, all the switches work properly. It reads 12v at both when the buttons are pressed, and when the door is open. I think it is immediatley burning out the lights. Or the polarity is backwards, But i dont think it would matter with those kind of bulbs.
Old 05-03-2006, 11:51 PM   #6
Polarity is not an issue. Mine had the same troubles. Its a supra thing.
The trouble is in the light assy., not the door switches.
I found the ground circuit does not make a good contact, for one thing.
I also had to screw with it all for 3 hours. I had to re-solder the wires to the terminals 3-4 times to make a goog connection. It was a real nightmare project, but they've been working now for 3 years.
Old 05-04-2006, 01:17 AM   #7
tonystarks
Default wow
yeah I'm too lay to screw with my lights for that long. i just use the visor mirror to pack my bowls......
86.5 MK Trey
7MGE
K&N Filter Kit
cheap ass exhaust
Old 05-04-2006, 04:06 AM   #8
Isphius
Isphius's Avatar
well some bulbs for cars are meant to be 6v but they have resistors and diodes that only make them work with a certain polarity, and so they can run on 12 volts. Same with LEDs, becuase they are diodes. But i need my dome light to work, because i deliver pizza. lol. Its very helpful
88 supra dome light removal help Jjona5 MKIII Supra 3 09-04-2014 06:10 PM
Damn dome light jdbones MKIV Supra 5 06-05-2010 05:43 AM
light on dash that tells you a light is out D_Train MKIII Supra 7 08-04-2007 05:10 PM
