Old 03-08-2006, 12:57 PM   #1
scruffboy
scruffboy's Avatar
Question Checking Thermostat
I recently had a new water pump installed, and the mechanic said he thought I didn't have a thermostat because he heard water rushing through as soon as he started it. I did my own test, where I started the car and squeezed the upper radiator hose and did not feel pressure of water flowing through. That would mean there is a thermostat, wouldn't it, as the thermostat opens when the engine heats up. Besides opening the housing, is there a sure fire test to tell if you have a thermostat. Also, everything seems to run normally. The car heats up after driving a little while, but not to fast. I really don't think this is true about not having a thermostat but I would like to find out for sure. I drove this car all winter without problems.
Thanks,
Scruff
Old 03-08-2006, 05:44 PM   #2
j3pz
the easiest way to tell would just take apart the thermostate. its not hard, wont take alot of time, and if you wanted to you could replace/ put in a thermostate. they are pretty cheap, i think like 5bucks. id put on some sealant to make sure it seals good though. also if you decide to do this,drain the radiator or put something under the car to collect the coolant. i know you probably arent a dumby but im just reminding you...
Old 03-08-2006, 05:53 PM   #3
scruffboy
scruffboy's Avatar
Default Re: Opening Housing
Okay, sounds good, but if it is there, is there a gasket that I will wind up destroying and need to replace?
Old 03-08-2006, 08:48 PM   #4
Fuel
Fuel is on a distinguished road
There is a rubber seal around the thermostat, other than that there is no other seal or gasket in you way. I replaced my seal but you dont have to if is in good condition.
Fuel is offline   Reply With Quote
Old 03-09-2006, 01:40 AM   #5
Just get a new thermostat AND a seal (reusing the old seal always leaked for me). Thermostats are supposed to be replaced every 2-4 years.
And don't over tighten the bolts.
Old 03-09-2006, 01:35 PM   #6
scruffboy
scruffboy's Avatar
Default Re: Thermostat
Okay, Mr.Nickleye, I will replace my thermostat. Does it matter where I buy it. Toyota wants $25 for the thermostat and seal. I'm sure Autozone will be much cheaper, but will I be getting my moneys worth? Should I stick with the Toyota Parts or go after market? One more thing, do I need to use a sealer of any type like silicone or something?
Thanks,
Scruffboy
Old 03-09-2006, 05:49 PM   #7
j3pz
i got mine from autozone for like $5. i think we put some sealant between the two housing peices, not sure but it couldnt hurt.
installing thermostat sd88supra MKIII Supra 8 06-18-2010 02:23 AM
thermostat ethan12510 MKIII Supra 8 06-28-2007 01:40 PM
Which Thermostat? scruffboy Non-Generation Specific Questions 4 03-01-2007 11:18 AM
Thermostat Necessary? Bullz_EyE MKIII Supra 16 01-02-2007 12:12 AM
1jz thermostat 160 degree stock ecu daiagaru2 MKIII Supra 2 08-03-2005 05:38 PM
