Old 03-02-2006, 01:42 AM   #1
Basic Bear
Basic Bear is on a distinguished road
Default Towing A Supra
I have to move a 92 supra and was going to use a car dolly. I was told that the chin on the supra is too low and I will not be able to drive the car onto the ramp. Does anyone have any suggetions or any other help would be appriciated.
Basic Bear is offline   Reply With Quote
Old 03-02-2006, 01:52 AM   #2
ddmcse
ddmcse's Avatar
Cool
2X6 boards to lessen the angle
there is a ball right in the center of the trailer/doly that is a radiator wrecker
using some baords to take away the steep pitch of the dolly ramps should help
^\ ramp
^\--------- put the boards on the ramps
get the idea?
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 03-02-2006, 01:57 AM   #3
Basic Bear
Thanks for the info. I noticed North Bay on your web page?? Is this where your are?
Old 03-02-2006, 06:35 AM   #4
mrnickleye
mrnickleye's Avatar
Are talking about one of those kind that you rent from Uhaul, that only gets 2 wheels off the ground ?
If so, and you have an automatic transmission, don't tow without disconnecting the drive shaft. You will fry the trans.
5 speed will be ok in neutral.
Don't forget to release the parking brake.
Old 03-09-2006, 12:24 PM   #5
Basic Bear
All went very well with the tow. We had to use two 2x6 boards under the ramp to reduce the angle of the lift. The front chin spoiler would have contacted the ramp if we did not use the boards. Thanks for the help
