Old 01-10-2006, 03:18 AM   #1
TxSpeedBoy
TxSpeedBoy's Avatar
TxSpeedBoy is on a distinguished road
Default Oil pressure?!
What should my oil pressure read at idal and at 40+ mph?
Supra Project 06... 1987 Turbo.
18" Enkei RS5. K&N Filter. Magnaflow custom exhaust.
"I got a pair of subs for my girlfriend...Good traid huh?!
TxSpeedBoy is offline   Reply With Quote
Old 01-10-2006, 03:52 AM   #2
Mine reads about 40 at 40mph.
Old 01-10-2006, 04:53 AM   #3
kwnate
What year? My 91t idles at 6-7psi. 30-40 lbs at 40mph. Remember our pumps are low pressure high volume. Also the stock gauge is slow to reacted in my experiance.
Nate
Old 01-10-2006, 05:08 AM   #4
TxSpeedBoy
TxSpeedBoy's Avatar
1987 turbo. Mine reads more than half below the center line(close to the bottom line) and reads just above the center line at 40+mph. I put a quart of oil around every 3 days cuz I burn and leak oil. Sux huh?! But I just wonder if I should bring it up to 40 for when I am going 40+? I am really concerned because I read that the block is great and really strong, but can NOT tollerate low oil pressure. So this has me greatly concerned.
Old 01-10-2006, 05:13 AM   #5
kwnate
6psi at idle is fine. Low oil pressure will kill the 7m, but it seems to me like yours is fine. The low oil will kill the 7m very quickly. Always keep it full, some run an extra quart for insurance.
Nate
Old 01-10-2006, 10:50 AM   #6
^ yeps
i believe stock specs are 4.6psi for idle... low pressure
fix the leaks eh
Old 01-10-2006, 08:05 PM   #7
scruffboy
scruffboy's Avatar
Default Re: Oil Pressure
My 89 N/A hits 40 psi at running speed. I think that's normal. Someone said something about slow gauges. It seems all my gauges are slow. When I gas up, it takes about 15 minutes or more to register. Is this a normal Supra thing?
James in NJ
Old 01-11-2006, 03:49 AM   #8
My fuel gauge is slow to come up, too. When its on 'E' there's 3 gallons left. When the warning light comes on, there's 2 gallons left.
My oil pressure gauge works pretty quick. The others are quick, and accurate.
They all seem normal, by any standard.
7MGE oil pressure Arne (Denmark) MKIII Supra 14 07-31-2009 10:07 PM
Oil Pressure Sender!? spudz29212MKIII MKIII Supra 8 05-06-2008 01:41 PM
Tire pressure? dannydavi Non-Generation Specific Questions 11 08-16-2007 06:03 AM
oil pressure johnkarl MKIII Supra 2 11-05-2006 02:11 PM
