Old 01-04-2006, 07:15 PM   #1
scruffboy
scruffboy's Avatar
Cool OK You guys talked me into doin it myself
I would like to replace my valve cover gaskets. There was some oil on 2 of my plugs. Are there two gaskets, or is it one big sheet? Will I have to scrape off old gaskets? Will crap fall in my engine? I have NA so throttle body should not be that hard. Mr.Nic says 3/8". I thought everything was metric? Where should I start when taking off throttle body? Will I have to take off intake manifold to get left side valve cover off? If I can pull this off, then I can do my own tune-ups and not have to worry about was this or that done. Any help would be appreciated. Oh, and sorry Mr.Nickleye, the drive from NJ to California is a bit much for me to locate an honest mechanic, which I'm sure you are.
Thanks folks,
James in NJ
Old 01-05-2006, 01:24 AM   #2
mrnickleye
mrnickleye's Avatar
Yep...bit of a drive, but well worth it in a good running supra. You could "see" America.
3/8" drive metric sockets is what I meant. You will probably need a universal swival adaptor too. You only need to take off the "Y" part of the intake. You can leave the throttle body on "it".
get a valve cover gasket set from the parts house. it should have all the needed gaskets.
If the #3 VC gasket (center one to seal spark plugs boots) is crappy looking, you'll have to order it from the toy dealer ($35).
Gotta go now, I'll check back later tonight.
Old 01-05-2006, 02:21 AM   #3
ddmcse
ddmcse's Avatar
Cool
scruff you better make sure you don't have any more cooling system problems before you worry about some oil around the cam covers . just hate to see you do twice the work on those covers
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 01-05-2006, 12:09 PM   #4
scruffboy
scruffboy's Avatar
Thumbs up RE: more coolant problems
Yeah, I was thinkin along those lines too. But I did get it pressure checked and they found no more leaks. I have driven this car kind of hard, and it has 127,000 on it, in a former thread someone felt the HG might have been replaced already. I think I'll wait for the weather to get a little nicer (maybe 3 months). Question for Mr.Nickleye, it sounds like you are tellin me there are 3 gaskets, 2 valve cover and center, is this correct? If it is, my center one is shot. And thanks, I see what you mean about the "Y", and last night I took lots and lots of pictures. I would suggest that to anyone, as I now have a reference if something falls off. You guys are very helpful. Thanks for everything.
Sincerely,
James (Scruff) in NJ
Old 01-05-2006, 08:23 PM   #5
mrnickleye
mrnickleye's Avatar
You don't absolutely have to have the #3 center gasket, as it is there to keep debri out of the spark plug holes. If you spray clean your motor, Water will get in, even with a new gasket. I put a new one on when I did my BHG because I want things right, and I know the gasket will last another 10 years.
Buying supra need advice guys sisqojazz Non-Generation Specific Questions 1 03-21-2007 10:47 PM
I need you guys opinion on this 1994 Supra Jiwon Non-Generation Specific Questions 2 06-14-2006 01:58 AM
Hey guys, should I purchase this? ravE MKIII Supra 1 03-18-2006 08:09 AM
Can some of you guys give me some info on these cars? Big Jimbo MKIII Supra 5 01-07-2006 08:24 PM
Sup Guys..!!!! Ruben Non-Generation Specific Questions 29 07-06-2005 09:38 PM
