Old 12-03-2005, 10:47 PM   #1
Chomper
Chomper is on a distinguished road
Default mkiv transmission noise?
Is it normal for the mkIV transmission to be loud?
Chomper is offline   Reply With Quote
Old 12-04-2005, 06:27 AM   #2
TRAFIK
TRAFIK's Avatar
TRAFIK is on a distinguished road
ummm auto, stick,, how many miles,, describe the problem??????? ?????????????????????????????????????????????????? ??????????
anything???????
--===Give me 2jz-Gte or give me death!===--
TRAFIK is offline   Reply With Quote
Old 12-04-2005, 08:55 AM   #3
Chomper
manual. just noisier when clutch is not step on.
Old 12-04-2005, 01:22 PM   #4
TRAFIK
TRAFIK's Avatar
well I heard that trans noise on sticks ( supras) is normal like in the 6speed
case.. but if you go to the mkiv.com problem section it will tell you about transmission noise...
http://www.mkiv.com/faq/faqtt.html#transmission3
can anyone give him some more info?"
Old 12-09-2005, 01:50 PM   #5
Gigler
Gigler's Avatar
Gigler is on a distinguished road
Talking Pay to Check
Thrust bearing , happens when you take your foot off the cluch and quietens when clutch is pressed, sounds like a thrust bearing to me, and try ATF 50/50 mix with gearbox oil, that helps too.
Gigler
Gigler is offline   Reply With Quote
Old 12-09-2005, 11:15 PM   #6
Chomper
My second gear grinds when shifting in normally. I would have to shift very slow for it not to grind. Will it cost a lot to fix?
86.5 auto transmission removal HELP!!! elmer MKIII Supra 13 04-06-2010 10:41 PM
Supra or Bmw? Greglatta Off Topic Forum 90 10-07-2009 06:37 AM
Want to learn about the Mkiv Supra? pwpanas MKIV FAQ 6 09-06-2008 05:37 PM
Should I try to rebuild my transmission, or leave it to experts? Busted Knuckles Non-Generation Specific Questions 1 04-15-2008 01:20 AM
Blown transmission 1985Supra MKII Supra 2 01-31-2007 07:56 AM
