Old 01-04-2005, 10:32 PM   #1
paige's supra
paige's supra is on a distinguished road
I have been working on my 87 Supra for the last couple of days... installing new cd player, taking off window tint, putting on new rear tires.... just little odds and ends... The only thing that was reallt taken apart was the center counsol around the cd player ad shifter.
After putting on the tires this morning, I went to move it out of the garage and it wouldn't start. It wouldn't even turn over. The battery is fine. Is there any suggestions?
paige's supra is offline   Reply With Quote
Old 01-05-2005, 12:41 AM   #2
when you try to start it what happens?
does it click or do anything?
leave the key in the off position and get a piece of wire and connect it to the little wire with a spade terminal on it going to the starter motor, then connect the wire you just put on to the positive side of the battery... does the engine now crank?
i would assume that by you saying shifter your car is manual? if it's auto it could be the neutral start switch on the transmission, it will probably need replacing
let us know how you get on
Old 01-25-2005, 05:13 AM   #3
snafu54
snafu54 is on a distinguished road
did your old tape deck have a anti theft alarm in it if so go to your toyota dealer and get a code for your supra. if it had a anti theft system it will prevent your car from starting.
snafu54 is offline   Reply With Quote
Old 01-26-2005, 09:24 AM   #4
ohh i never even gave that a thought.. the factory anti theft alarm...
i didn't think of it coz we don't get them from the factory here hehe
yep great possiblity
good luck and hope you get it sorted
Old 02-07-2005, 09:54 PM   #5
shadow
Guest
Posts: n/a
[COLOR=green] i had the same problem with my supra, I changed several things which include my starter and battery, but it ended up being a simple little electrical problem. what you need to do is go to autozone or a place like it and ask for a reelay. THis device gives and extra energy boost to your starter.
good luck,
