Old 10-21-2005, 04:21 PM   #1
gemstone
gemstone is on a distinguished road
Question turbo problem
I think I have an oil leak in the area of the turbo, but cannot see point of origin. oil drops on garage floor and on return oil pipe. 87 supra has 77,000 original miles, with recently replaced head gasket. Oil lines were not removed form turbo during rebuild. Did not notice leak before engine rebuild. Any help would be appreciated. Question, if turbo seals are leaking, would they leak internally into the intercooer pipe or external at the turbo?
gemstone is offline   Reply With Quote
Old 10-22-2005, 09:36 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
usually when the oil seals go they mainly start leaking straight into the exhaust and it smokes like a mofo
if it's coming down the oil drain pipe then it is more than likely from the oil line... jack her up, put on jackstands.. get torch shine up there... and see if you can find the origin of the leak
GL
Pics of my build.
Do a diagnostic first!
Old 10-25-2005, 09:03 AM   #3
lethalwithasupra
lethalwithasupra is on a distinguished road
hi. hey mine started leaking oil from the turbo oil pipe when i took the turbo out to do head gasket ( wont make that mistake again. edit : those mistakes ), and around the oil pressure sender unit for some reason. oil feeder pipe attaches to block just behind it. think they just dont like being disturbed.
just something else to check.
So I bought this old Honda bike, an NSR250. Bit of a street racer, I guess. I'm told they're fast.
Delivering it home with a friend driving the Supra for the first time. I drop gears and make a scream from the twin pipes flowing down this pony's flanks and it takes off like it's tail's on fire.
I look back when the Honda gets to its tap-out and the Supra's only two lengths behind. No one I've let ride my bike has told me its slow, they've all loved the thing. That car is a good thing indeed.
lethalwithasupra is offline   Reply With Quote
Turbo dropping problem! 88 MARK3 Non-Generation Specific Questions 7 06-14-2006 05:17 AM
Turbo problem ? redmaro MKIII Supra 6 03-29-2006 08:30 AM
